Old Thu, Apr-16-2009, 08:18:00 AM   #1
RAWST
Reputation: 0 RAWST is on a distinguished road
Default Center Dash Rattle Fixed!
Hello
I've been suffering from dashboard rattle for few months. I've finally found the rattle and fixed it. For those of you who had suffered, hope this is your solution.
This rattle which I though it was coming from inside of dashboard wasn't actually from inside of dashboard but it sounded very much like it was coming from inside of dash. It sounds like loose plastic touching plastic coming from center dash area, specially when engine's cold.
Problem was the moulding which located behind the cabin filter housing.
1. pop the hood and locate the cabin filter cover with 3 locking pins.
2. Remove cabin filter cover and filter.
3. You'll find 4 screws underneath the wiper area, remove them
4. Locate the plastic wire cover on front of housing and unclip to remove plastic cover.
5. Remove the housing
6. Once housing removed, you'll find a wall with 2 screws on top left, right, and 1 locking pin on all the right center of the wall. Remove 2 screws and locking pin and remove the wall.
7. Once wall removed, you'll find rubber moulding placed around metal body.
Tap it around and move it around and you'll notice it's loose and it flaps. Remove moulding completely
8. Fill the gap all the way with gang load of silicone.
9.Put moulding back in place and everything else in its place.
It took me about an hour to finish and NO MORE DASH RATTLE.
For door panel rattles, I'm going to remove both driver's and passenger's door panel and drive for few days to find out exactly what is causing rattle. I'll give you guys an update once I'm done.
I've learned and discovered many great things about my M in this forum and I hope this minor fix would bring someone's smile back.
Good Luck
Jump to top RAWST is offline   Reply With Quote
Old Thu, Apr-16-2009, 11:06:28 PM   #2
bzzsan
10
bzzsan's Avatar
Reputation: 0 bzzsan is on a distinguished road
2005 AW/IR 6speed--
Jump to top bzzsan is offline   Reply With Quote
Old Thu, Apr-16-2009, 11:18:55 PM   #3
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
very nice find i dont have this rattling, but im sure it will help others out who does
Old Thu, Apr-16-2009, 11:32:29 PM   #4
jaykalia
Starships - Meant To Fly
jaykalia's Avatar
Reputation: 0 jaykalia is on a distinguished road
Thanks for sharing
2001 LSB ///M3
Jump to top jaykalia is offline   Reply With Quote
Old Fri, Dec-11-2009, 06:40:51 AM   #5
gogogadgetm3
Reputation: 0 gogogadgetm3 is on a distinguished road
would replacing that moulding with a new one fix the rattling as well? I think this is the source of my rattle.
Its a gentle humming rattle when the engine is cold and at idle. Its gotten progressively worse where even when the engine is warmed up the humming rattle is still there when the car is at idle.
Jump to top gogogadgetm3 is offline   Reply With Quote
Old Fri, Dec-11-2009, 07:23:26 AM   #6
///M3-QTR
ॡحمدॡ
///M3-QTR's Avatar
Reputation: 0 ///M3-QTR is on a distinguished road
Qatar
I think I have this rattle thanks for sharing !
Euro 01 IR/IR ///M3 113K miles|281rwhp on DD
^ SOLD^
Engine: aFe drop in filter, SS race exhaust |Drivetrain: AS Ultimate SSK w/ UUC DSSR, ZHP shifter knob, GSP clutch pedal.
Suspension : AST 5100's 600/750 w/ Vorshlag camber plates, PF RTAB's, RE RSM, UUC adjustable rear camber arms, TMS reinforcement kit & endlinks |Braking: Cool Carbon, StopTech SS lines| Exterior: Alufelgen SF-71's, VORS(1x1) CSL bumper, trunk and diffuser,OEM rear LED's, blackout front grills, CF side grills , smoked corners and side signal lights, TFX conversion, Umnitza 4300K V2's angle eyes, Euro wide convex mirrors| Interior: US spec trunk release button, OEM alcantara boot, OEM alum pedals.
Jump to top ///M3-QTR is offline   Reply With Quote
Old Fri, Dec-11-2009, 01:04:43 PM   #7
B5N_BM
Reputation: 0 B5N_BM is on a distinguished road
England
Good post, I have a slight rattle from the back end of my car, sounds like somewhere near the rear speakers, so think this weekend im going to pull it all apart and find it as can drive you little mad at times lol
Jump to top B5N_BM is offline   Reply With Quote
Old Fri, Dec-11-2009, 01:58:13 PM   #8
HaroldC
Yes, it's stock.....
HaroldC's Avatar
Reputation: 0 HaroldC is on a distinguished road
Nice!
I've got that rattle too, and I wasn't looking forward to taking my dash apart to try to find it. Now I know where to look. I might just replace that seal, which isn't too expensive from the dealership.
It's part #2 in the diagram:
Jump to top HaroldC is offline   Reply With Quote
Old Fri, Dec-11-2009, 01:59:47 PM   #9
HaroldC
HaroldC's Avatar
Here's the part # for that seal: 64 31 8 370 409
Old Sun, Mar-14-2010, 11:53:15 PM   #10
gogogadgetm3
Can someone who has replaced the molding (pn: 64 31 8 370 409) confirm that it fixes the rattle? Or are we left with only the silicone method mentioned by the OP?
center, dash, fixed, rattle
Rear Deck Rattle... FIXED ThatOneGuy E46 M3 (2001-2006) 75 Tue, Jul-22-2008 05:17:56 AM
Fixed H/K rattle!! (pics...) r6338 E46 M3 (2001-2006) 15 Tue, Jun-29-2004 06:08:13 PM
Dealer Fixed Speaker Rattle!!!! dfdoc525 E46 M3 (2001-2006) 9 Sat, Mar-06-2004 01:16:40 AM
Speaker Rattle Fixed! Thai E46 M3 (2001-2006) 12 Thu, Jul-31-2003 02:10:29 PM
Parcel-shelf rattle fixed! Pike E46 M3 (2001-2006) 0 Fri, Dec-27-2002 05:33:43 PM
Discussing Center Dash Rattle Fixed! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
