Old Tue, Apr-21-2009, 08:45:29 AM   #1
Crazyfool
Littering and?
Crazyfool's Avatar
Reputation: 0 Crazyfool is on a distinguished road
Germany
Default M50 Manifold Cold Startup Issues
I have done several searches on this issue, but I couldn't find any solutions.
I have an E36 M3 with an M50 manifold. When the engine is cold, it takes about 3 cranks for the car to start up. I am guessing that it's losing fuel pressure somewhere, but where? I have already checked for leaky injectors, vacuum leaks and broken check valves.
Has anyone found a solution to this problem yet?
M3 Carbon Black — SMG — Cinnamon
Yamaha R1
RX-7 FD3S R1
504 RWHP — 11.318 @ 129 — video
Jump to top Crazyfool is offline   Reply With Quote
Old Tue, Apr-21-2009, 01:49:18 PM   #2
TheM
TheM's Avatar
Reputation: 0 TheM is on a distinguished road
Sounds like a vacuum leak. Check for any hoses that you may have forgotten to connect.
Jump to top TheM is offline   Reply With Quote
Old Tue, Apr-21-2009, 10:32:20 PM   #3
Crazyfool
Littering and?
Crazyfool's Avatar
Germany
I've already checked all vacuum lines, and there's not a single leak anywhere.
Any other ideas?
Yamaha R1
RX-7 FD3S R1
Old Wed, Apr-22-2009, 01:02:50 AM   #4
TheM
TheM's Avatar
Originally Posted by Crazyfool View Post
...I am guessing that it's losing fuel pressure somewhere, but where?..
Put a fuel pressure gauge in the system and find out for sure.
Are you getting any CELs or codes?
Old Wed, Apr-22-2009, 04:12:22 AM   #5
EauNatural
EauNatural's Avatar
Reputation: 0 EauNatural is on a distinguished road
Did you just install the M50 manifold? or did this problem just come about abruptly?? A bad/clogged fuel filter caused my old E46 to act like this only when cold ONLY. (needed 2 cranks). I had the car smoked too thinking it was a vacuum leak but nada..
E36 ///M3/4/5 Arctic Silver on Black - The Latest & Greatest
E46 ///M3 Carbon Black on Black - The Former
"If you haven't tried, you haven't lived"
Jump to top EauNatural is offline   Reply With Quote
Old Wed, Apr-22-2009, 06:00:27 AM   #6
Crazyfool
Littering and?
Crazyfool's Avatar
Germany
I already did a pressure check with a gauge. It does drop a small amount, but nothing that would explain why it takes exactly 3 cranks to start up.
This started happening the second I installed the M50 manifold.
Yamaha R1
RX-7 FD3S R1
Old Wed, Apr-22-2009, 06:32:23 AM   #7
m3_858
Пьяный Парень!
m3_858's Avatar
Reputation: 0 m3_858 is on a distinguished road
Russian Federation
How did you install the m50 mani? Kit if yes which one, home made rig? Also I remember having to disconnect something from the starter if I recall right, maybe you messed something up during the install. Can you be more specific.
Jump to top m3_858 is offline   Reply With Quote
Old Wed, Apr-22-2009, 06:50:23 AM   #8
Crazyfool
Littering and?
Crazyfool's Avatar
Germany
I installed it like you would install any manifold.
It's my understanding that this is a common issue with the M50 manifolds. Hasn't anyone found a solution for this yet?
Yamaha R1
RX-7 FD3S R1
Old Wed, Apr-22-2009, 06:53:32 AM   #9
m3_858
Пьяный Парень!
m3_858's Avatar
Russian Federation
You can't just straight install m50 manifold on s52. Maybe that's your problem You need a kit of some kind or something home made to accommodate for all the differences between the m50 and whatever the hell the 96+ manifold's called. I've used the eurosport kit, most people don't want to spend the extra money and go with eric's kit, some get all homedepot made parts and do it themselves. It's not a direct swap so I don't know what you're talking about.
Old Wed, Apr-22-2009, 07:10:43 AM   #10
Crazyfool
Littering and?
Crazyfool's Avatar
Germany
The M50 came with all necessary parts for the installation.
Yamaha R1
RX-7 FD3S R1
cold, issues, m50, manifold, startup
Please Help With Startup Issues dlpfcb E46 M3 (2001-2006) 4 Tue, Dec-02-2008 03:46:45 AM
Let's talk cold startup routines. fiveightandten E36 M3 (1992-1999) 24 Thu, Sep-27-2007 08:14:46 PM
For those that have had the squealing on cold startup...??? tony(topaz,SMG) E46 M3 (2001-2006) 14 Sun, Nov-12-2006 11:56:30 PM
M50 E36 M3 manifold conversion kit w/or w/out manifold SoCal M3 Parts for Sale/Wanted 7 Fri, Aug-25-2006 03:46:29 AM
Very rough idle at cold startup snopro67 E36 M3 (1992-1999) 14 Thu, Aug-12-2004 02:22:22 AM
Discussing M50 Manifold Cold Startup Issues in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
