Old Thu, Apr-23-2009, 12:23:07 AM   #11
Cheeze
Cheeze's Avatar
Reputation: 0 Cheeze is a jewel in the rough
Originally Posted by maranelloman View Post
Meadowlands parking lot just after a big snow?
Insane fun, but not the practice on pavement I'm looking for. Trying to simulate what I might encounter on the track in high-speed turns, like turn 10 (I think) at VIR, the downhill lefter immediately after the climbing esses. Not in terms of the actual geometry of that turn obviously, just in terms of practicing oversteer at the speeds you'd go around turns like that in the dry.
Jump to top Cheeze is offline   Reply With Quote
Old Thu, Apr-23-2009, 01:17:40 AM   #12
maranelloman
Very Large Member
maranelloman's Avatar
Reputation: 0 maranelloman is on a distinguished road
IMO you're better off doing that in snow in a parking lot than on dry asphalt at speed. Everythign is magnified in snow, even at low speeds, and there is little to no risk.
Professional Racing & Driving Coach
Jump to top maranelloman is offline   Reply With Quote
Old Thu, Apr-23-2009, 07:21:35 AM   #13
lagunasecablue
The SMMMURF
lagunasecablue's Avatar
Reputation: 0 lagunasecablue is on a distinguished road
I think the skills at managing oversteer are all pretty similar. What works on say, a gokart, or in a parking lot at 30mph, will help you at 70mph.
The inputs are just much more delicate at higher speeds, the caster in the alignment will help but you need to be on your toes to not make an oversteer situation worse than it is by not recognizing it. It needs to be second nature... i.e. feel the rear stepping (even before it actually pitches) and throw in a little correction.
Try outdoor gokarting. Not the indoor stuff or kiddie outdoor stuff, but 50-60mph Tag gokarts... your reflexes will be SHARP.
2009 M3 Sedan Alpine White/Black 6MT - no moonroof, stock
2004 M3 Coupe Laguna Seca Blue/Black 6MT - no moonroof, RAC RG63, Dinan/Koni
2004 S2000 Sebring Silver/Black 6MT - OEM hardtop, stock
1995 Miata - SCCA Spec Miata SFR '08 Champion
Maintained and modded by Performance Technic
Jump to top lagunasecablue is offline   Reply With Quote
Old Thu, Apr-23-2009, 11:04:16 AM   #14
maranelloman
Very Large Member
^^ good point ^^
Old Thu, Apr-23-2009, 12:19:30 PM   #15
Mvez
RS-aholic
Mvez's Avatar
Reputation: 0 Mvez is on a distinguished road
+1,
High speed oversteer is normally not like low speed oversteer due to high torque, on-throttle situations...it's usually related to balance (technique). Corrections need to be subconscious.
The problem with high speed oversteer is when you over-correct or "jerk" the wheel or throttle in reaction. At higher speeds there is less time to correct mistakes.....feed in adjustments calmly, but deliberately, as it helps to keep the car balanced.
Putnam Park is a great place to go for huge run-off room.....let's see...Turn 1, Turn 4, and Turn 5 all offer plenty of run-off room. Hell, the whole track has tons of run off room except for the last 2 corners (9&10), so you literally have to try to hit something, but there are some fast, tricky, off-camber corners. It's ideal if you want to drive on the limit without fear of bending metal, or if you have a really nice car that you want to learn to drive quickly.
Since BMP will now be my home track, I'm going to miss all that wide open space....
2007 GT3RS - Guard 40/60 LSD | GMG sway bars | Swift race springs | Cup toe links | Factory Clubsport Rollbar and Seats | Wevo Engine Mounts | Studs | CCW C14 wheels | Schroth |
2005 M3 Coupe - GC Race/Track S/A | ERS 700#F, 800#R | Turner Bars | Turner Subframe F/R Reinforcements | RE RTABs | RE Rear Control Arms | RE Engine Mounts | RE Tranny mounts | TreeHouse Racing FCABs | AKG Rear Subframe Bushings (75D) | GC Camber Plates | GC Weight Jackers | Clutchmaster Stage 1 | OEM CSL headers | SS Section 1 w/ High flow cats | Dinan CAI | Dinan Stage 3 software | Dinan SSK | AA Exhaust (Gen 3) | Bimmerworld Intake Elbow | Turner Oil Cooler Kit | Stoptech ST-40, 355F | ZCP Rear w/ bushing upgrade | SS Lines | ARC-8 9.5"F, 10"R | Turner Studs | Turner Racing Pedals | Raven 4pt. Rollbar | Schroth | Braille B3121 | No sunroof |
'04 X5 4.4i
Jump to top Mvez is offline   Reply With Quote
Old Thu, Apr-23-2009, 04:39:13 PM   #16
elbert
I brake for tailgaters
Reputation: 0 elbert has disabled reputation
Wales
If you do happen to get oversteer in Turn 10, my advice is to put both feet in. I've lost count the number of cars wrecked on the left hand wall where the driver tried to save it from a spin.
You also might want to think why someone would get high speed oversteer in Turn 10.
From what I've seen, most people getting oversteer there are those forcing the car into the turn, trying to hit the apex when in reality they missed the turn in point. Which really more of a n00b mistake, considering how much room there is on corner exit.
Something to think about.
Jump to top elbert is offline   Reply With Quote
Old Thu, Apr-23-2009, 05:59:12 PM   #17
sips56
sips56's Avatar
Reputation: 0 sips56 is on a distinguished road
Track event that gives you access to a skid pad??
1999 e36 M3 with plenty of track goodies
2008 e60 535i on Breyton 19's Turbo Tuner, Euro Delivery
Jump to top sips56 is offline   Reply With Quote
Old Thu, Apr-23-2009, 06:01:06 PM   #18
Cheeze
Cheeze's Avatar
I don't disagree, just looking for the practice at-speed. I try to take my car out in the snow at every opportunity.
Good points, but again I was just giving an example of the speeds I want to be practicing oversteer at as opposed to the 'why' oversteer is occuring. I hear you on the both feet in / not forcing it though. I took that turn a little too fast one time and instead of forcing it in I decided to just drive straight off the outside of the turn (and down the big hill... ).
Putnam Park - great info, a little far away for me. Good info for other members though, keep them coming even if they're not in the NorthEast.
I'll have to look into some karting events. Any noob FAQ links or anything? Do those types of events generally allow you to rent karts or do you have to bring your own?
I got this PM from a member regarding an auto-x at Hershey that may offer some higher-speed stuff than a standard auto-x:
Phil, I would check out central Porsche Club's website, cpa-pca, they host what is advertised as the largest autox east of the mississipi, it's held at one of the Hershey Park parking lots. They host about four or five a year, last week's was very long sweeping turns for an autox, I was often countering oversteer. My daughter, who I instruct at HDPDs, does these with me to help her with exactly what you are talking about. Any car type is permitted, and you don't have to be a PCA member to attend. If your're not a PCA member it will cost about $40.00. Very informal and relatively speaking, you get a lot of track time, six runs, then they ask you to flag for another heat
Appreciate all the input so far.
Old Thu, Apr-23-2009, 08:01:21 PM   #19
NPalacioM3
NPalacioM3's Avatar
Reputation: 0 NPalacioM3 is on a distinguished road
Spain
That is one hell of a turn. Too bad the rest of the track is kinda boring.... but man that is a corner that seperates the men from the boys. I would really hate to see what would happen if you lost it there. Eeek!
I agree. Go find a good kart place nearby or suck it up and buy a used and decent (you dont need anything crazy) 80cc kart for 1K or so. Take it along with some cones to a large, vacant office parking lot on the weekends. Setup the cones and jump in the kart. Many professional race drivers keep sharp by driving karts in the off season, they definitely will keep you on your toes. Great practice, I love karts.
Nick
Real race cars don't have roofs or fenders.
Jump to top NPalacioM3 is online now   Reply With Quote
Old Thu, Apr-23-2009, 08:55:04 PM   #20
Cheeze
Cheeze's Avatar
http://www.youtube.com/watch?v=Fqfv2tYhkDk
(he only oversteered because he apexed about 2 days early and ran off the tarmac...but same consequences obviously!)
Any good karting forums or classified links? I'm a noob to karts...
highspeed, oversteer, practice
High-speed shimmy notopM3 E36 M3 (1992-1999) 21 Sat, Sep-27-2008 12:24:03 AM
Cornering at high speed aquasition E46 M3 (2001-2006) 20 Mon, Jul-02-2007 12:23:57 PM
F1 practice on Speed now! M3_Dust Off Topic 7 Fri, Jun-08-2007 07:08:29 PM
High Speed, High Rev Power loss - Diagnoses? Braymond141 E36 M3 (1992-1999) 7 Thu, Jan-05-2006 09:48:15 PM
F1 free practice on speed vision KILO15 E46 M3 (2001-2006) 27 Fri, Jun-17-2005 05:08:25 PM
Discussing How to practice high-speed oversteer? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
