| M3 Track: Racing and DE Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! |
#31 |
Automotive Lighting Innovations
![]() Location: Oakland NJ
Nice video you have some skills
Caesar Rowinski - LIGHTWERKZ 2009 BMW M3 Sedan - Space Gray FS: PFC Pads |
#32 | |
http://www.driftnasty.com/index.php?...f6bb96fce22e8a http://www.phillydrift.com/viewtopic.php?f=18&t=318 http://www.driftpa.com/forum/viewforum.php?f=44 This is a WAY different crowd than you're probably used to at track days. But once you get used to all the turbo blow-off valves stuck through the hoods and missing bumpers , it's a great way to get drift practice on a track.
-Alan '04 M3 - SMG ![]() '94 E36 track car '87 Mazda RX7 Hotchkis sways - 2.5deg front camber - 18x9.5 VMR CSL reps - Nitto NT-01 275s - PFC06's - Schroth Quickfit |
#33 |
I agree that practicing car control at low speeds is an excellent way to develop a tactile relationship with your car and limit the consequences. But I don't agree that those learned responses can transfer directly to a high speed environment. I have done enough drifting -intentional and unintentionaly- to believe that that particular envelop of speed, yaw, and driver response could be tragic at higher speeds. Places where I used to run flat out in my 320i ITB car turn into noticable corners in my current, much faster car. Turn 10 at VIR, which has been cited, is a breath taking corner that has a high risk/reward ratio. If you have the tail hung out there before the crest and you have not early apexed, you have a problem. Your entry speed or angle or both needs adjustment. But a little full throttle oversteer once you are pointed down hill works great. I assume that we are talking here about minor to moderate oversteer that is most easily controled by throttle modulation rather than significant steering input. I believe that yaw angles common in drifting would be hazerdous at high speeds. If drifting type angles were the fast way around the corners, wouldn't there be clouds of smoke everywhere during a race? There always other corners at tracks with lower speeds where oversteer can be induced for practice. Slip angles that roughly match the tire design slip angle are about as far as you want to go at high speeds. High speed driving events and club racing (or other) driving schools are a good place to look for the edge of the envelop with your particular car setup. Once you are comfortable out there on the edge, you can start working on the car to push it's limit out a little further. Final obersavation: if someone thinks VIR is boring, they aren't going fast enough. Cheers!
#34 | |
Riding the knock sensor
![]() Location: Thousand Oaks, CA
![]() | Platte Forme A.G. Aero | JRZ RS Pro | SS Stepped | Borla | 4.10 | Apex ARC-8 | Stoptech | Recaro HANS | Kirk | Schroth | |
#35 |
![]() Location: Raleigh NC
Hah! Its unsettling me for the late Feb school as well.
#36 |
#37 | ||
Are we on the same page now?
#38 |
Hey, same page all along. Drifting is a great way to learn car control- that was the first sentence in my post: "I agree that practicing car control at low speeds is an excellent way to develop a tactile relationship with your car". My hat's off to those drifting guys- great car control- I love watching them do their thing. But the emphasis in drifting is a setup and style to create oversteer and a slide whereas I think that the setup and style for a road course is, by and large, designed not to create oversteer and a slide. My overall comment was responding to what sounded like a desire to learn to deal with high speed oversteer in more of a track environment (rather than drifing environment) where the vehicle dynamics and consequences can be significantly different. We're cool.
#39 |
Right, I gotcha. When the OP mentioned oversteer, I was thinking he meant after the rear end broke loose - at which point it's damage control. You were talking about optimizing slip angles, which is certainly higher up on the driving skill pyramid.
Both are way fun! ![]()
#40 |
![]() Location: Stratford, CT
High speed oversteer scares the living Bejesus out of me.. Learning to do some controlled drifting is also something I'd love to do. The practice handling such situations would definitely give me more confidence around high speed corners.
| highspeed, oversteer, practice |
| High-speed shimmy | notopM3 | E36 M3 (1992-1999) | 21 | Sat, Sep-27-2008 12:24:03 AM |
| Cornering at high speed | aquasition | E46 M3 (2001-2006) | 20 | Mon, Jul-02-2007 12:23:57 PM |
| F1 practice on Speed now! | M3_Dust | Off Topic | 7 | Fri, Jun-08-2007 07:08:29 PM |
| High Speed, High Rev Power loss - Diagnoses? | Braymond141 | E36 M3 (1992-1999) | 7 | Thu, Jan-05-2006 09:48:15 PM |
| F1 free practice on speed vision | KILO15 | E46 M3 (2001-2006) | 27 | Fri, Jun-17-2005 05:08:25 PM |
