![]() Location: Cherry Hill
So I just got a set of studs for my car and I'm being told by Dan at DERMotorsports that I should not be using any loctite on the hub end of the stud and instead just use anti-seize lube on both ends. I know a lot of you guys here are running studs with loctite and usually I go with what the majority of the forum uses but I know Dan is very knowledgeable. So what are your opinions?
2003.5 Silver Grey///Imola Red M3 6MT
NorCal's Valve Adjustment guy
![]() Location: SF Bay Area
I have a stud kit and use blue medium loctite. I take my wheels off and on often and nothing major has happened.
![]() 01[LSB][Cinnamon][6 Spd.]ESS VT475|3000lbs.|6.31lbs./hp PM me for valve adjustment and inspection 1&2 deals! |
Track addict
![]() Location: Denver
Why is he telling you to use antiseize on the part going into the hub? Does he want them to back out of the hub while you're driving?
Use Red Loc-tite on the part going into the hub. If you need to remove them, you still can, but they won't back out on their own...
'89 Porsche 944 Turbo LS1 475hp track machine '04 Audi A4 Avant Daily Driver |
#4 |
Old Skool
![]() Location: Zoo York
Dan has always given really good advice. Not sure why he would go against using loctite... I used Loctite 242 (red) on the ends which attaches to the hub and haven't had an issue with the studs walking out when breaking loose the nuts.
I can't imagine why he would advise using never seize on any end...
1988 M3 - Henna/black on black alcantara 2012 Ducati 848 Evo Corse |
#5 |
Automotive Lighting Innovations
![]() Location: Oakland NJ
red loctite is the way to go if you ask me.
Caesar Rowinski - LIGHTWERKZ 2009 BMW M3 Sedan - Space Gray FS: PFC Pads |
#6 | |
#7 |
Track addict
You can easily take them out if you need to even if you use red loctite.
#8 |
whats the trick to removing the studs if i used red loctite?
#9 |
![]() Location: Buffalo
Lil heat and a little more force, no big deal
#10 |
Track addict
Not even. Just double nut em.
| kits, loctite, stud |
| Wheel Stud Conversion Kits | Eric1855 | E36 M3 (1992-1999) | 23 | Sat, Dec-22-2012 01:53:05 PM |
| Wheel locks that work with stud kits! | Obioban | E46 M3 (2001-2006) | 41 | Fri, Dec-17-2010 10:01:44 PM |
| Wheel locks that work with stud kits! | Obioban | E36 M3 (1992-1999) | 5 | Sun, Mar-30-2008 12:13:36 AM |
| Need Epoxy that works better than LocTite (DO NOT BUY LOCTITE) | bigneil | E36 M3 (1992-1999) | 14 | Wed, Sep-20-2006 12:00:42 AM |
| Lock nuts for those with stud kits | Arnee | E46 M3 (2001-2006) | 11 | Mon, Aug-14-2006 07:39:32 PM |
