Old Thu, May-14-2009, 07:33:48 PM   #1
sleepsi
Reputation: 0 sleepsi is on a distinguished road
Default rear end noise while turning right...
i just traded my 02 330ci up to a 02 m3 smg 70k. great trade. i have had this car for about a week or so now and i am hearing a weird rubbing noise in the rear when i turn to the right really hard. i never experienced this noise in my other e46 but i know almost all of the parts are different. also when i shift there is a bump noise in the rear of the car its of course louder the harder im in it. any suggestions? i havent had anyone put it on a lift here. i live in a very small town the closest bmw dealer is 100 miles away! there is only one indie shop and ive heard they are $$$$ thanks for your input everyone.
Jump to top sleepsi is offline   Reply With Quote
Old Thu, May-14-2009, 08:59:16 PM   #2
NJiM3built
NJiM3built's Avatar
Reputation: 0 NJiM3built is on a distinguished road
diff fluid! clunk is normal. dont forget...smg shifts hard brah...gotta get used to it
Jump to top NJiM3built is offline   Reply With Quote
Old Thu, May-14-2009, 09:09:51 PM   #3
sleepsi
i know i need to change it but would any sort of bushing etc etc cause this? i love the smg shift
Old Thu, May-14-2009, 09:15:59 PM   #4
Mpowerza
Reputation: 0 Mpowerza is on a distinguished road
South Africa
ive had experience with this on my m.
Let me guess, it happens when the car is cold, like in the morning or if its been parked for a few hours.?
Common problem on the M's..almost as common as the Clunk or bearing issue !
9/10 its your diff. The clutches inside your diff are causing the noise at the wheels. It starts on the one side, and if u do nothing about it, both wheels will start making the grinding/rubbing noise, it gets worse over time.
Get the diff fluid drained and put in the BMW Diff fluid with FM booster. There is a additive in there that stops the noise. Once the oil is in , do about 8-10 figure 8's , driving in a parking lot or something to get the oil over the diff clutches. the noise should dissapear. If it doesnt, have a tech look at the diff. Worst case is you need to replace the diff, but the fluid should do the job. With my diff, i had a brand new diff in , and 4 mnths later this issue started. Changed the oil and now its better....
Sometiems the bmw techs put in the wrong oil and the noise starts ...theres 2 bmw official oils, the one doesnt have the additive, and this could be your problem.
If i were you, Id get it looked at ASAP, before it gets worse and u do permanent damage.
2001 Steel Grey, 6M/T, S/R ERB, HK Audio , AC Schnizer Exhaust, 19" BBS LM Reps, Tein SP
Jump to top Mpowerza is offline   Reply With Quote
Old Fri, May-15-2009, 02:29:11 AM   #5
chatcher
Reputation: 0 chatcher is on a distinguished road
http://www.m3forum.net/m3forum/showthread.php?t=264280
current rides:
2009 Zr1
2012 Navigator
2008 4.8i E70 X5
2008 F450 Dually
2013 135i
2005 E83 X3 3.0
2003 rc51
1999 F350 Dually
Running out Garage space!!
Jump to top chatcher is offline   Reply With Quote
Old Fri, May-15-2009, 05:00:09 AM   #6
NJiM3built
NJiM3built's Avatar
Sway bar links I believe could be next to look at if the fluid doesnt fix this or maybe a bent control arm. But before freaking out I would change the fluid "yourself" (save you prob 130$) which will take 30minutes ish, 10min of work and 20 of waiting, do as told above doing figure 8s and what not, then move on to the next source if the problem persists.
http://www.m3forum.net/m3forum/showthread.php?t=252529
end, noise, rear, turning
Help! Humming Noise From Front End When Turning Left? vrmac E46 M3 (2001-2006) 7 Mon, May-04-2009 04:57:01 PM
Noise from the rear end Hi5ingmf E46 M3 (2001-2006) 11 Tue, Jan-29-2008 05:35:02 AM
noise from rear end kev1031 E46 M3 (2001-2006) 6 Thu, Mar-01-2007 03:52:17 PM
Noise in rear of 2001 M3 when turning Plumberwass E46 M3 (2001-2006) 11 Sun, Nov-30-2003 03:46:01 PM
Rear end noise Q? CWASH36 E36 M3 (1992-1999) 1 Thu, May-15-2003 04:20:12 AM
Discussing rear end noise while turning right... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
