#21 |
![]() Location: Tacoma, WA
Update
Official word from BMW is the camshaft broke. The service writer is not in today but that’s the word I’m getting from another writer. Has anyone heard of this before? Is it common for camshafts to break especially at 56,000 miles? Thanks again |
#22 | |
As far as bent valves and piston damage, it really depends on the motor.. Some motors bend valves, some don't. Typically it's a 50 50 shot depending on if the engineers made it so tight that the valves will open far enough to collide with the pistons. This seems more common on High performance motors and I'm assuming you guys who say he did already know this engine is a valve bender.. |
#23 | |
#24 |
#25 |
ensure the Vanos is completely normal, as I still bet it was a factor in the cam breakage. If my car was apart like this I'd probably buy the Dr Vanos rebuilt unit out of pocket and have it put on.
ADS
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1. Sold to my son, still in the family! 06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit. |
#26 | |
X_X
![]() Location: Indianapolis
![]() Gruppe M | Autosolutions SSK | CSL trunk/diffusor | Rotora BBK | Ground Control Coilovers 525f/600r |
#27 |
Ain't the cam lubricated by like oil and stuff ? What about the 100k motor warranty from the mother ship ? Does it apply to your car ?
#28 | |
///M-azing
![]() Location: New York\City
#29 |
The cam does have oil lubrication but can still break. A drop in oil pressure (caused by a faulty oil pump, clogged pickup tube, or clogged journals), Dirt in bearing/journals, and several other RARE but possible situations cause camshafts to break on occasion. I'm not too sure what vanos is but I imagine its the technologically advanced valve timing system used in the M3. I imagine this puts abnormal stresses on cams and when faulty can cause a cam to break as well..
#30 |
I was refering to the factory 6yr/100k warranty (that applies to some e46 M3's) on all parts lubricated by oil, not the cause of the failure. Sounds like he's covered anyway.
http://en.wikipedia.org/wiki/VANOS
| 000, 2004, broke, chain, miles, timing, w or 56 |
