Old Sun, Jul-12-2009, 03:41:01 PM   #41
tylernim
Reputation: 0 tylernim is on a distinguished road
never seen this thread before. glad it was bumped to the top. makes me rest easy all of the sudden.
Jump to top tylernim is offline   Reply With Quote
Old Sun, Jul-12-2009, 04:38:38 PM   #42
lsrteg
carbon 03 e46 m3
lsrteg's Avatar
Reputation: 0 lsrteg is on a distinguished road
Talking
Originally Posted by pjgo View Post
PN 26122282495, center mount, aluminum, is #7 in the attached image. Thanks!
PJ
Thank you guys i hate that damn noise. Im doing it asap.
Jump to top lsrteg is offline   Reply With Quote
Old Tue, Aug-04-2009, 09:08:24 PM   #43
Krozi
Hau Rein!
Reputation: 0 Krozi is on a distinguished road
So this is a definite fix? How many other members have done this?
Jump to top Krozi is offline   Reply With Quote
Old Thu, Aug-27-2009, 04:10:24 AM   #44
futballa10
futballa10's Avatar
Reputation: 0 futballa10 is on a distinguished road
Bump, really like this post, I was scared when i started hearing noises like that changing from 1st to 2nd. Didnt happen on my test drive of the car. Thought i bought a bad car guess im not the only one with this clunking noise. Never new there was such thing as the "M-clunk".
Jump to top futballa10 is offline   Reply With Quote
Old Thu, Aug-27-2009, 10:12:50 AM   #45
Voodooking
Reputation: 0 Voodooking is on a distinguished road
United Kingdom
I really hate the M-Clunk. It embarrasses me when other people comment on it. Like for example if I'm parking at low speed and shifting from 1st to 2nd and passengers or colleagues say: "What's that noise, is there something wrong with your car?" and you have to explain that even though you have a nice car that people envy, it still makes a heap of clunky noises like an old wreck.
My car only makes the noise some of the time. I find that if the weather is hot it helps, the tranny is less noisy and more smooth. It's strange that it doesn't happen all the time.
I kind of think that the more you read up on it the more different reasons people give for it, and everybody suggests replacing something different. I would love for it to be gone, but feel I could spend a fortune replacing endless parts and still be in the same situation.
I do think however, that if I had bought my car brand new, paid £40k+ for it, and it had been the same clunky noisy mess there is no way I would have been happy. I would have taken it straight back to the dealer.
Jump to top Voodooking is offline   Reply With Quote
Old Thu, Aug-27-2009, 11:28:55 AM   #46
JWL
Reputation: 0 JWL is on a distinguished road
I assume this only pertains to cars with a 6MT not an SMG.
JWL
2002
SMG
CB/B
Jump to top JWL is offline   Reply With Quote
Old Thu, Aug-27-2009, 11:50:24 AM   #47
John_T
John_T's Avatar
Reputation: 578 John_T has a reputation beyond reputeJohn_T has a reputation beyond reputeJohn_T has a reputation beyond reputeJohn_T has a reputation beyond reputeJohn_T has a reputation beyond reputeJohn_T has a reputation beyond repute
Pertains to all, as all are the same past the gearbox. You need to distinguish, however, between drivetrain play noises and the LSD clunk which is part of it's function in power distribution between the wheels, forward and reverse. The LSD clunk is not a constant and occurs only under certain functional circumstances. As stated in the SIB, there is deliberate play rear right.
Jump to top John_T is offline   Reply With Quote
Old Thu, Aug-27-2009, 12:02:49 PM   #48
bmwm3dave
Reputation: 0 bmwm3dave is on a distinguished road
The M clunk drives me mad!
Here goes, Ive had the car 2 years its a 6MT 2001 with 53000 miles
3000 miles ago I had my clutch done, the flywheel was ok. Before this I had a mild clunk I considered acceptable. Since the clunk has become more noticeable.
If I have it in 1st or 2nd gear and accelerate decelerate by dabbing the pedal in quite rapid succession so the car takes up any play in the driveline both ways, there is a very noticable loose sounding clunk / clang coming from under the car and I must admit it sounds towards the front.
Its definately not suspension, subframe or anything like that, it is deffo the driveline or mounting points.
I am quite mechanically minded and take on most jobs myself but on this occasion I decided to take it to an independant BMW specialist garage.
They drove it, had it on the ramps, inspected what was visible, charged me £50 and said nothing to worry about everything is tight but there is wear in the diff. They showed me how it could be moved by turning the rear wheels and it did clunk a little.
They said put up with it, not worth changing till it breaks which it wont!
After all this I still read and have read every single clunking post on here.
I am still under the opinion it can be fixed.
Maybe there is two different issues one being the diff and the other being the driveline centre mount.
Does this sound familiar with anyone elses noises?
I'm interested to hear anything at all that might lead me to this annoying noise.
Dave
Jump to top bmwm3dave is offline   Reply With Quote
Old Thu, Aug-27-2009, 12:09:53 PM   #49
John_T
John_T's Avatar
Drivetrain is more clanky, LSD is more thud-clunk.
On any drivetrain, the play is taken up in one direction on applying power, then released and taken up in the other direction upon letting off power or shifting in reverse. Some play is normal and necessary, but in any case the noise will be reduced by the smooth applying or releasing of power.
Old Thu, Aug-27-2009, 12:15:32 PM   #50
MrKaira
MrKaira's Avatar
Reputation: 0 MrKaira is on a distinguished road
thanks for the info!
///M3 - Dinan short shifter/ZCP wheels/DEPO smoked corners
SS 350Z TT - Built motor/twin turbo
Jump to top MrKaira is offline   Reply With Quote
brandnew, car, fixed, infamous, mclunk, shifts
Discussing Infamous "M-Clunk" fixed, car shifts like brandnew! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
