Old Mon, Jul-20-2009, 07:41:26 AM   #1
azndrunk74
Reputation: 0 azndrunk74 is on a distinguished road
Taiwan
Default Shifter in 1,3,5th "pops" back towards neutral
I don't know what happened, maybe I've been banging through the gears too hard ever since I've been S/C'd but today I noticed my shifter in 1st, 3rd, and 5th kind of "pops" back 2cm or so towards neutral when I let go of the knob. It shifts fine but annoying because it moves back a few cm. It doesn't do it in 2nd, 4th, and 6th.
Are there common bushings or clips that go bad in the shifter? Would a short shift kit solve my problem? I did a search but couldn't find a thread about the same problems I'm having. Thanks in advance for any insight!
LSB|Cinnamon|VCSL GTS3 Diffuser|VCSL Bumper|VCSL Single Sided CF Bootlid|UUC EVO2|AVIC Z3|Bilstein PSS9|GC RSMs|SPC Aluminum ARCAs|Volk LE37|ZCP Brakes|Headers|Euro Cats|AA Gen3
Jump to top azndrunk74 is offline   Reply With Quote
Old Mon, Jul-20-2009, 01:33:26 PM   #2
vmwerks
Valley Motorwerks
Reputation: 0 vmwerks is on a distinguished road
South Korea
Sounds like you have some wear in your bushings. This would be a good time to install an SSK along with the bushings since you won't be duplicating work.
Disclaimer: I have never had this happen to me, maybe I just don't pay attention since I am watching the road.
Walter Ford
President
Valley Motorwerks
Pointsix Motorsports
___________________________________________
VF Engineering Stage 2 / Rogue Octane SSK / Rogue El Diablo Muffler / Rogue Section 2 with EVC / Bilstein PSS11's / Vorshlag Camber Plates / Turner Swaybars / Rogue FCAB's / Powerflex RTAB's / Rogue RSM's / MORR VS7 Alloys / Sumitomo HTRZ3's / FT 19x8.5 245/35r19 / RR 19x9.5 275/30r19 / Front Brembo 355mm / Rear Brembo 345mm / SS brake lines / Vorsteiner Lip / CSL trunklid / Black out gills / Black out kidney's / Smoked corners / OEM LED tails / Umnitza LED Halo's / Suede wheel / Suede shift boot / ZHP shift knob / Intravee IPOD / Custom NAV splash
Jump to top vmwerks is offline   Reply With Quote
Old Mon, Jul-20-2009, 01:49:20 PM   #3
silbul
Reputation: 0 silbul is on a distinguished road
I had something similar, where the gearbox didn't engage a gear (sometimes 2nd, sometimes 3rd). I think it was due to not being sure I had clicked into gear because of the feel I got. I just completed installing the AS SSK (difficult and time-consuming installation). It is much more positive in feel, and I haven't had the problem since (yet?).
Jump to top silbul is offline   Reply With Quote
Old Mon, Jul-20-2009, 07:49:37 PM   #4
azndrunk74
Taiwan
Thanks guys, a SSK might be the way to go for me right now.
I think I have a better way for me to describe it right now - 1st,3rd, and 5th moves a notch farther than it's originally supposed to when I shift into those gears. That's why it pops back into position, because that's where the shifter is supposed to sit (if that makes any sense). Any idea what wore/gave out to allow my shifter to do that?
Old Mon, Jul-20-2009, 07:58:16 PM   #5
///NNM
previously: milovanov
///NNM's Avatar
Reputation: 0 ///NNM is on a distinguished road
Russian Federation
that's EXACTLY what happened to mine few weeks back.
i got UUC short shift kit to replace, here is why:
the OEM bushing is plastic compound, covered by a metal clip.
when the bushing wears out, the clip doe snot hold no more and flies off (permanently lost due to being under the car and wind and stuff)
page 4 - http://www.uucmotorwerks.com/pdf/shifter_install.pdf
temporary: reverse, 1, 3, 5, shift while pressing DOWN on the shifter.
get the UUC kit and install - it solves the problem of the wear on top of the bushing, completely different design.
oh, yeah, the unless you are doing the install yourself, by the book it's 3 hours of labor due to extreme tightness of space... do it yourself per instructions above.
also, if you are doing it yourself, or paying shop to do it, i would go with new kit instead of just a bushing replacement because labor will be EXACTLY same time.
placing metal clip back on will only last until it pops off again, thus completely pointless and involves %80 of labor also...
Evolve Alpha-N | SuperSprint Headers | MS: Elbow | 4.10 | TMS: Pulleys, Camber Plates & Arms, Solid Diff mounts, Studs, Front/Rear Subframe Kits | ACS Strut bar | PF RTABS | UUC: SSK3, DSSR, tranny mounts, SS clutch, brake lines | H&R Front Sway | ST coils v1 | 18" BBS RCJ | Custom Vibrant Performance Exhaust
YouTube DIY Videos Sister 98 M3 2dr; Wife 04 X3 3.0
Jump to top ///NNM is online now   Reply With Quote
Old Mon, Jul-20-2009, 08:57:28 PM   #6
azndrunk74
Taiwan
Wow very very helpful, thanks! Can you describe what the clip that flew off looks like? I didn't see it on page 4..
Time to shop for a SSK now!
Old Mon, Jul-20-2009, 09:01:42 PM   #7
///NNM
///NNM's Avatar
Russian Federation
correction:
i do not think there was a clip, actually, i just assumed there was one and mine just flew off... cuz if i would be a car manufacturer, i would put it there.
either way, the problem is your stock nylon holder for the shifter, which gets destroyed by shifting to fast.
get SSK and you'll be fine, the reason for getting UUC - no nylon bushing!
page 5:
http://www.modbargains.com/images/Pr...fter%20E46.pdf
Old Mon, Jul-20-2009, 11:38:58 PM   #8
Eat.Sleep.Race
Bottle Fed
Eat.Sleep.Race's Avatar
Reputation: 0 Eat.Sleep.Race is on a distinguished road
had the same problem where it would pop out of gears, it was the shifter bushings or something along those lines, anyways went with the active autowerks ss kit and has been perfect ever since.
-03 BMW M3
-04 BMW M3
-05 Kawasaki ZX-10R
Jump to top Eat.Sleep.Race is offline   Reply With Quote
Old Mon, Jul-20-2009, 11:45:50 PM   #9
johnhk79
einpresstiefe
johnhk79's Avatar
Reputation: 0 johnhk79 has disabled reputation
South Korea
shift slower haha
Jump to top johnhk79 is offline   Reply With Quote
Old Tue, Jul-21-2009, 01:39:07 AM   #10
azndrunk74
Taiwan
John..you asking to shift like a girl? lol
///NM and BottleFed you guys are right, I took a look after work today and the plastic cup/bushing where the shifter sits in was shattered towards the front which allowed the ball joint to pop out of the cup when shifting into 1st,3rd,5th.
Thanks for the help guys!
5th, back, neutral, pops, shifter
Discussing Shifter in 1,3,5th "pops" back towards neutral in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
