Old Thu, Jul-23-2009, 07:09:11 PM   #1
mar32
mar32's Avatar
Reputation: 0 mar32 is on a distinguished road
Default Can less wide tires fix rubbing?
Right now im running 245/35 275/30 19s
Wheels: 19/8.5 front 19/10 rear
offset front -30 rear 22 mm
Could i run stock tire size and get them stretched.. or is that not a good idea? any help would be greatly appreciated!!
BTW, im on KWv2s, there not that low at all, i only rub on hard turns with 2 people in the car, thanks
2002 Jetta gls 6MT-sold
2004 VW R32-sold
2002 E46M3 CB/Grey coupe 6MT--sold
2006 E46M3 IR/Black Vert 6MT
2009 WRX STI
Jump to top mar32 is offline   Reply With Quote
Old Fri, Jul-24-2009, 02:08:49 AM   #2
kmurph
Reputation: 0 kmurph will become famous soon enough
I'm running BBS CHs which are 19x10 et20 in the rear. The tires are Toyo T1-Rs in 275/30, and I have 7" 60mm Eibach springs with Koni Sports. I had rubbing issues for quite a while, but ever since I had the rear aligned to -1.5 deg camber with 1/16" toe-in (each side), I rarely have problems...hopefully this helps. I wouldn't go with a narrower tire on a 10" wide wheel....275s are already stretched a little.
2007 Audi RS4 / GMG Exhaust
2001 BMW M3 - sold
Jump to top kmurph is offline   Reply With Quote
Old Fri, Jul-24-2009, 08:37:51 PM   #3
mar32
mar32's Avatar
ok thanks, i might try that, im also running in the front on u turns as well, can I take out the plactic lining thingy out from the front?
2004 VW R32-sold
2009 WRX STI
Old Fri, Jul-24-2009, 08:47:46 PM   #4
Toddzilla
Reputation: 0 Toddzilla is on a distinguished road
When I was running general exclaim UHPs in 275/30/19 in the back I got some rubbing, when I went to sumitomo HTRZ-IIIs no rubbing as they are slightly more narrow than the generals.
Jump to top Toddzilla is offline   Reply With Quote
Old Fri, Jul-24-2009, 08:50:13 PM   #5
bmw loe
Reputation: 0 bmw loe will become famous soon enough
What brand/type tires are you running?
-e92 335i 6MT Space Gray/Black M-sport, JB4 G5 ISO/DCI/CM Meth (CM10 nozzle)
12.612@114.74mph, 18psi on stock run-flat tires and plausible fuel pump codes sold
-e46 M3 6MT, sold
-e46 M3 SMG, sold
-E90 LCI M3 Interlagos Blue / Novillo Silver
Jump to top bmw loe is offline   Reply With Quote
Old Fri, Jul-24-2009, 08:54:08 PM   #6
Noodle555
My other ride is a beater : D
Noodle555's Avatar
Reputation: 0 Noodle555 is on a distinguished road
United Kingdom
What wheels are those? Look very nice.
GL with rubbing issue.
2002 M3 Vert TiAG/Blk - with every option
Mods: Clear Bra | Tints | Hardwired Passport SRX | Painted Bumper Reflectors | Keyhole Cover | 6000k Predator Chromiums | 6000k Philips Ultinons | 6000k HID Fogs | Philips Silvervision Corners | OEM LED Tails | LED Plate Lights | Trunk Lip Spoiler | Eisenmann Race | CSL Diffuser | CD/DVD Swap | Small Antenna | Blackout Grille and Gills | Smoked Corners
Purchased Mods Awaiting Installation: ZCP Brake Upgrade | CF Interior Trim | Royal F1 Paddles
Other Vehicles: 2008 X5 4.8i BSM/Blk - most options and a few mods| 2009 Chevy Silverado LTZ - fully loaded
Jump to top Noodle555 is offline   Reply With Quote
Old Sat, Jul-25-2009, 01:31:02 AM   #7
kmurph
I'm running Toyo T1-Rs, which I think are also a little narrower...plus, the sidewall is a little more rounded when compared to some tires.
2001 BMW M3 - sold
Old Sun, Jul-26-2009, 04:30:56 PM   #8
mar32
mar32's Avatar
continental contisport contact 3
2004 VW R32-sold
2009 WRX STI
Old Sun, Jul-26-2009, 04:32:33 PM   #9
mar32
mar32's Avatar
Linea Corse LM reps, thank you
Ok, how do you like that tire, im thinking about going to the ps2s
2004 VW R32-sold
2009 WRX STI
Old Sun, Jul-26-2009, 11:20:04 PM   #10
Rogacki89
Rogacki89's Avatar
Reputation: 0 Rogacki89 is on a distinguished road
Poland
I have Ps2's in the rear of my car and since I bought the car, I havnt experienced any rubbing at all with the OEM 19's at stock ride height
1996 Boston Green BMW 318i (SOLD)
2005 Jet Black BMW ///M3 6spd (SOLD)
1998 Arctic Silver BMW ///M3 5spd
2011 BMW S1000RR
Jump to top Rogacki89 is offline   Reply With Quote
fix, rubbing, tires, wide
Discussing Can less wide tires fix rubbing? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
