Old Thu, Oct-15-2009, 01:57:29 PM   #11
Gatehouse
///M Power
Gatehouse's Avatar
Reputation: 0 Gatehouse is on a distinguished road
ok, did some more research, and i got this part #
63217165973 BULB CARRIER LEFT
63217165974 bulb socket, right
I got them from Tischer's package here: http://www.trademotion.com/partlocat...catalogid=4462
I searched the part #'s and thats what i got. Can anyone actually verify before i order them from a bmw stealer?
Thanks guys!
| 2002 TiAg E46 M3 |
| TE37SL | TCKLine | SCSL | AS SSK | Rogue Engineering | Lightwerkz |
| Depo | Turner Motorsport | Revo R40 | Cobywheel | AFE | VividRacing |
Jump to top Gatehouse is offline   Reply With Quote
Old Sat, Jun-05-2010, 03:14:32 AM   #12
nos4you
Reputation: 0 nos4you is on a distinguished road
Did you ever figure this out?
Im in the same situation as you. lol
Also, did you also install the updated 03.5-up trunk lip lights?
I am wondering if I am going to need the bulb carrier for those coming from a 01-03.
Jump to top nos4you is offline   Reply With Quote
Old Sat, Jun-05-2010, 03:49:40 AM   #13
turbo_f22_pilot
turbo_f22_pilot's Avatar
Reputation: 0 turbo_f22_pilot is on a distinguished road
Do you have OEM LED tail lights? The trunk light carriers are different for the two different OEM versions.
OEM LED tail light conversion kit w/ part no.;
In order to finish FIRST, you MUST first FINISH !
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
Jump to top turbo_f22_pilot is offline   Reply With Quote
Old Sat, Jun-05-2010, 02:46:05 PM   #14
Gatehouse
///M Power
Gatehouse's Avatar
ill go pull the PN from the trunk lights just to be sure!
you also need the wiring harness for them as well, i believe it was $50 for both of them!
| 2002 TiAg E46 M3 |
Old Sat, Jun-05-2010, 02:55:07 PM   #15
nos4you
So If I want to get the upgraded trunk lights I also have to get the matching carriers and a harness adapter?
Old Sat, Jun-05-2010, 02:56:05 PM   #16
nos4you
Yes I got OEM Led's. I dont see a part # for the inner trunk light carriers in the link you supplied. It shows the outers, outer covers, cableset, and trunk lights only. unless they come with the trunk lights?
Old Sat, Jun-05-2010, 11:40:33 PM   #17
turbo_f22_pilot
Outer lights are your tail lights. Inner lights are your fog/reverse lights. Your trunk lights attach to the back of your outer tail lights. You reuse the existing bulb holders for the inner lights. The trunk light unit should be; (Left & Right Bulb Sockets (63217165973-974))
CAR:
MODS:
BMWCCA NCC
Old Wed, Oct-20-2010, 01:34:36 AM   #18
nos4you
the reverse lights fit perfectly, because they still use the 'bulbs', the larger rear tail lights dont have the 'bulbs' so they metal carrier and electrical distribution pieces arnt needed.
i may have to order these back pieces. fail.
Im still looking for the part #'s for the outer tail covers for the oem LED tails.
Anyone get these can verify?
The part #'s from tischer's site is for the holegen carriers not the LED carriers.
Anyone know where to order these?
Old Tue, Mar-29-2011, 05:23:53 AM   #19
deuce7
deuce7's Avatar
Reputation: 0 deuce7 is on a distinguished road
Default Re: LED Trunk lights? Hrm ...
i am!
What kind of M3 do you have?
I have an e46 2005 M3 and it seems like all I would have to do (to changing the lighting inside the trunk) is swap out the OEM festoon bulb with an LED type festoon bulb.
I actually just ordered some bulbs. I'll try to take some pictures of the lighting with the old bulb (yellowish tint) and then led bulbs (white). Not sure if it's going to be brighter, but we'll see.
e46 M3 Coupe - Alpine White
Jump to top deuce7 is offline   Reply With Quote
hrm, led, lights, trunk
Discussing LED Trunk lights? Hrm ... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
