Old Fri, Sep-11-2009, 09:45:31 PM   #1
ForcedInduction
Reputation: 0 ForcedInduction is on a distinguished road
Default Will be replacing my driveshaft center support and bearing. Need some advice.
I already dropped the whole exhaust, heat shield and I'm ready to pull the driveshaft out. How is this center support properly replaced? Also while everything is out, is there anything else I should consider replacing? Like transmission mounts or something?
03 Evo VIII 312whp - Became victim to Mass drivers
91 MKIII 1JZ-GTE 461whp Pump gas
89 Sil80 2JZ-GTE 721whp
01 IS300 2JZ-GE
02 ///M3
Jump to top ForcedInduction is offline   Reply With Quote
Old Fri, Sep-11-2009, 10:01:25 PM   #2
EricSMG
30 something
You must remove the entire driveshaft first. That's pretty easy. Then you'll need to split the two halves by removing the 18mm nut just inside the u joint. Then the center bearing can be pulled off.. you may need a puller for this. Be sure to mark the two halves before you separate them to ensure proper alignement when reassembling.
Regrease the rear CV... pack it full. Get a new gasket as well. Good time to replace the guibo. Tranny mounts are probably good to replace too.... easy and cheap.
All that said, a rebuilt drive shaft is roughly $400 so consider that.
'04 46M 6MT || '01 330Ci 5MT
Old Fri, Sep-11-2009, 10:29:08 PM   #3
ForcedInduction
Are there any aftermarket tranny mounts out there?
Old Fri, Sep-11-2009, 10:35:57 PM   #4
snook
Reputation: 0 snook is on a distinguished road
bimmerworld.
Jump to top snook is offline   Reply With Quote
Old Sat, Sep-12-2009, 04:27:42 AM   #5
ForcedInduction
Just ordered. Anything else I can change?
Old Sat, Sep-12-2009, 04:55:17 AM   #6
EricSMG
30 something
Not really except exhaust
Oh, you could change your tranny fluid since everything's out of the way.
Old Sat, Sep-12-2009, 11:04:39 AM   #7
ForcedInduction
Was told 60k mile service was just done before I bought the car, so they said tranny fluid was changed. Exhaust I would really love to change or more so headers, but either way I'd have to pass inspection with the stock exhaust first before upgrading.. They are getting strict here in MA.
Old Sun, Sep-13-2009, 09:45:22 PM   #8
ForcedInduction
Just ripped the driveshaft out and replaced the center support and bearing. The guibo is cracked :\ looks like I'll have to order one.
Old Mon, Sep-14-2009, 03:10:37 AM   #9
B at M obile W
It's the only car to drive everyday
B at M obile W's Avatar
Reputation: 0 B at M obile W is on a distinguished road
Good luck with the project!
Curious, why you are doing this?
'01 Blk/Blk M3 Coupe:
Current Mods: Custom painted ///M reflectors, Hardwired V1, 6k (D2S Bulbs, HID Fogs, Orion V2 angel eyes, white LED corners), Smoked LED taillights, Blacked out sidemarkers, H&R Sport springs, ///M valve stem covers, Black ///M3 License plate frame, Black ACS front lip w/ custom carbon fiber ///M logos, Tint 20% x 5, Rogue Engineering El Diablo Exhaust
Jump to top B at M obile W is offline   Reply With Quote
Old Mon, Sep-14-2009, 04:10:57 PM   #10
bimmerbm3
bimmerbm3's Avatar
Reputation: 0 bimmerbm3 is on a distinguished road
yeah i was about to tell you about the guibo. You might as well take the entire drive shaft to a your local machine shop. They can do it with out breaking a sweat. check out my my guibo i just replaced.
http://i662.photobucket.com/albums/uu342/millioncapone/DSC03809.jpg
Cars: 09 Nissan GTR *SOLD Tranny Failure
05 E46 M3 Verty SMG (as of 175 shot)
06 Dodge Ram SRT-10 Quad Cab SC'd *NEW
Mods- Rotora 6pot/4pot BBK front and rear / 4.10 gears / NOS Wizards Custom Direct Port Nitrous and MAX Extreme Progressive Controller and C16 Fuel Cell / Ignition Solutions Plasma Coils / Full Turner Race Pulley Kit / PWR Aluminum Radiator / VPD Oil Cooler / AFE Stage 2 intake / EVO sport headers / UUC Stage 2 Flywheel / Meisterschaft SuS Section 1 / Rogue X-Pipe w/ EVC Cutout / Remus Exhaust / No cats or resonators / CF interior / Kenwood Excelon DNX 8120 and Type R components all around / Custom Gauge Pillar / DINAN Ported Throttle bodies / Active custom NOS tune and SMG software / HPF Stage 3 Pistons and Connecting Rods ... all of these little mods equal 100,000 rwhp
...NEW !!! Stage III D/A Street Head & Camshaft 8/27/09 *OS Giken STR Twin Disk Clutch Kit
Jump to top bimmerbm3 is offline   Reply With Quote
advice, bearing, center, driveshaft, replacing, support
Discussing Will be replacing my driveshaft center support and bearing. Need some advice. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
