Old Fri, Sep-18-2009, 04:34:07 PM   #1
MJM3
MJM3's Avatar
Reputation: 0 MJM3 is on a distinguished road
South Korea
Default Stupid Diff
heres the story:
like most M3,s my rear diff was leaking a little bit. I took it in for repair under warranty about a year ago.
about 8k miles later, she starts to leak again. I took it in again for the same problem, they replaced it under warranty, problem solved.
I'm on the freeway this morning going to work and all of a sudden i feel my car losing power. I gave it a little gas and the car starts to steer to the right and loses power again.
After I get off the freeway I start noticing a scraping sound in the rear along with a loss of a lot of power. I have no SES light or any engine problems. I look under the car and the same seal is busted again but seemed a little more severe this time.
Could a low diff oil level cause only one wheel to engage on the LSD?
thanks a bunch guys. I'm about to call the dealer but I wanna do my homework done before they assram me with BS.
I do RTAB/FCAB/Coilover installs and CDV deletes for the SD area.
http://www.m3forum.net/m3forum/showt...ight=rtab+tool
Jump to top MJM3 is offline   Reply With Quote
Old Fri, Sep-18-2009, 04:43:50 PM   #2
Highpower11
Highpower11's Avatar
Reputation: 0 Highpower11 is on a distinguished road
Sorry to hear about this. I would first inspect for leaks and then check the diff oil level myself before taking it to the dealer to see where it is at. I hope the internals were not starved of fluid causing a partial lockup of your diff.... bad news in an case. Let's hope it's still covered under warranty.
___________________
06 /// M3 ZCP, 6MT, Interlagos Blau Metallic \ M-Alcantara\ Volk RE30\ VMR 701 (winter)\ CDV delete\ ESS ECU Tune\ RPI Scoops\ BMC Filter\ Turner aluminum Race Pedals\ Rogue FR 10mm spacers\ Rogue RSM\ Vogtland Springs\
\ V1 Hardwire\ DICE/iPhone\ Smoked corners\ painted reflectors\ ZHP illuminated Alcantara shift knob\ HID fog's\ LightWerkz TFX\ Nav, Power seats & Sunroof delete\ Coming Soon: Euro Headers & Cats
Jump to top Highpower11 is online now   Reply With Quote
Old Fri, Sep-18-2009, 04:55:33 PM   #3
swc
swc's Avatar
Reputation: 0 swc is on a distinguished road
How do we check the diff fluid level?
02 M3 vert AA SC...(Gone)
06 C6 Z06...(Gone)
02 M5...(Current)
07 997 turbo mods begins
Jump to top swc is offline   Reply With Quote
Old Fri, Sep-18-2009, 04:56:55 PM   #4
55fanatic
I drive the competition
Reputation: 0 55fanatic is on a distinguished road
Greece
Over the last couple days I have been hearing a grinding noise when I take hard right or left turns... about back at the end of June I replaced my diff fluid... wondering if something might be going on
"Making friends, one state trooper at a time"
mods: Eibach lowering Springs, OEM 19s(summer for now), OEM 18s(for winter + track), 330d shifter lever, goodridge SS brake lines, HP Plus brake pads, Delsa CSL Diffuser, VIS CF hood, Flat black kidneys, DDM 55W xenon retrofit(hi and low beams), MyCarr 60+ LED Angel Eyes, Depo Smoked Corners, Alpine flip out, Alpine BlackBird Navigation, Alpine Blue tooth module, Escort 8500 hardwired, 20% tint, Vanilla Pine tree air freshner
Jump to top 55fanatic is offline   Reply With Quote
Old Fri, Sep-18-2009, 05:10:21 PM   #5
MJM3
MJM3's Avatar
South Korea
man.. i wish i could check the level right now.
no tools.. no jack.. im sucking.
Old Fri, Sep-18-2009, 05:36:53 PM   #6
J02 M3
1,2,6th
J02 M3's Avatar
Reputation: 0 J02 M3 is on a distinguished road
Depending on the year, its eithier a 12 or 14mm Allen head socket (or wrench)
you will need to take out the plug above the drain. Pull the plug and (have the car on a level surface) the fluid level should be right at the bottom of the plug.
02 M, Gloss black side gills, Tein S-Tech's,
DBA brakes, 245/35/19 & 275/30/19.
Jump to top J02 M3 is offline   Reply With Quote
Old Fri, Sep-18-2009, 05:41:34 PM   #7
.333 snubnose
.333 snubnose's Avatar
Reputation: 0 .333 snubnose is on a distinguished road
possibly...but that could also be a wheel bearing.
Jump to top .333 snubnose is offline   Reply With Quote
Old Fri, Sep-18-2009, 06:42:46 PM   #8
swc
swc's Avatar
Sorry but that didn't answer my question. That's how much fluid supposed to be at. I meant how I can check the level of current fluid in the diff case.
06 C6 Z06...(Gone)
02 M5...(Current)
Old Fri, Sep-18-2009, 06:46:54 PM   #9
MJM3
MJM3's Avatar
South Korea
Default diff fluid
if your fluid level is good, you should be able to feel it when u remove the the fill cap (upper cap) and stick your finger in it,.
Old Fri, Sep-18-2009, 07:00:44 PM   #10
HuffE46M3
HuffE46M3's Avatar
Reputation: 0 HuffE46M3 is on a distinguished road
I had a grinding noise when i made hard turns...I replaced my diff fluid with bmw SAF-XJ (Part # 83-22-2-282-583-M9). When I got a tune up/inspectionII I had mentioned the grinding noise; the mechanic used redline 75/90. This did not help at all, so I requested the bmw SAF-XJ. Sometimes I still hear a slight noise, but sounds much much better than before.
Jump to top HuffE46M3 is offline   Reply With Quote
diff, stupid
Discussing Stupid Diff in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
