Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E36 / E30 - Parts for Sale/Wanted
E36 / E30 - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E36 or E30 only.
Old Mon, Sep-21-2009, 12:58:20 AM   #1
Default Tons of E36 stuff... want it all gone
Everything needs to go. I've made bundles of parts. The bundles are sold as one lot and one lot only. I will NOT pick out parts... you either buy the whole box which is price very well, or walk away.
Click on the small images for full-size!
E36 M3 Engine Components - $100.00 + Shipping
-Two S52/M52 Manifolds - Scratched - need to be cleaned
-Two M3 ASC Bodies - One Actuator
-Two Oil Separator Valves - 80k miles - no leaks
-Two ICV's - Both work great
-Brackets, seals, other misc stuff
-Basically it's 2 nearly complete S52 manifolds + most accessories - no tubing
E36 M3 Electrical Components - $100.00 + Shipping
-Cluster backing with coding plug - ~100k miles or less
-Cluster backing with coding plug and screwed up Mcoupe overlay frame - 100k or less
-3 Brown bottom window buttons + Sunroof auto close controller - Great condition
-2 White bottom window buttons + frames - good condition
-Light dimmer - good condition
-98 M3 blinker and wiper arms
E36 M3 Interior Trim Pieces - $40.00 + Shipping
-Coupe dash radio frame
-2 consoles - good condition, not perfect
-OBDII heater vent cable
-Mirror cover passenger side
-Center console ashtray
-Rear console ashtray
-M3 Rear view mirror
-unkown ashtray
-Coupe BMW emblem - 7/10 condition
-Coupe trunk shocks
-Coupe door handle bezels
-Replica LTW Badges
-Coupe door handle trims
E36 M3 Interior Trim Pieces - $80.00 + Shipping
-Black Coupe Kick Panel - Good condition
-Black Glovebox dash side panel - Good condition
-3 Coupe rear window seals - Good condition - need cleaning
-Coupe lower door trims
-///M3 Door Sills - need double side tape removed - one has cracked end
E36 M3 Lighting Components - $150.00 + Shipping
-Left and Right Coupe Tail light covers - Minor scratches
-Driver Clear Depo - Single tiny crack - New
-Passenger Smoked Depo - Cracked side - New
-Aftermarket Coupe Passenger Clear - OK
-Hella Foglight Brackets - Perfect
-30 LED DDM Angel Eyes - New
-2 Pairs of 35watt Ballast - 1 Pair NEW - 1 Pair Slight used
-PAIR 8k 35watt 9006 Bulbs - New
-PAIR 5k 35watt H7 Bulbs - New, one has dremeled base to fit h1
-Non matched pair of Phillips DS2 Bulbs - Good - OEM
Jump to top Braymond141 is offline
Rate Seller View Rating
Old Mon, Sep-21-2009, 12:58:58 AM   #2
E36 Water pump - Not for M3 or 328 - $20.00 + Shipping
E36 M3 Project Bosch Headlights - $100.00 + Shipping
Good condition - tab condition show in pics. Purchased these to do a retrofit into, forgot about them and never finished.
-One lens is cracked - good inner lenses
-Other lens needs cleaning inside and out
-Both housings and inner frames need cleaning - inner frames are mint and include all wiring
-Missing rear caps and misc stuff not shown
E36 M3 Misc Components - $100.00 + Shipping
-M3 Rear diffuser - Minor melting on one side - Good condition
-S50 valve cover - modified bolt holes - needs work - 5/10 condition
-S52 valve cover - cracked (can't really be seen) - strut bar wear - 6/10 condition
-OBDI E36 A/C Lines R134
-E36 M3 (1996) Rear Sway bar + Bushings
Old Mon, Sep-21-2009, 03:05:12 AM   #3
imapirate30
Reputation: 0 imapirate30 is on a distinguished road
Germany
if you ever want to part anything please email me at hayesburrow@gmail.com
Jump to top imapirate30 is offline   Reply With Quote
Old Mon, Sep-21-2009, 06:17:03 AM   #4
I am...
Old Tue, Sep-22-2009, 01:13:46 AM   #5
fitchesbass
Like a carpenter that makes stairs
fitchesbass's Avatar
Reputation: 0 fitchesbass is on a distinguished road
bump for a good guy. Good luck bray.
Jump to top fitchesbass is offline   Reply With Quote
Old Tue, Sep-22-2009, 04:38:41 AM   #6
Thank you Derek.
I'll take 250 for everything minus the Bosch headlights want it allll gone!
Old Tue, Sep-22-2009, 01:54:19 PM   #7
Highneiken
Reputation: 0 Highneiken is on a distinguished road
Guyana
Can you PM me...I'm interested in the interior trim kit
Jump to top Highneiken is offline   Reply With Quote
e36, FS:, stuff, tons
Discussing Tons of E36 stuff... want it all gone in the E36 / E30 - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E36 or E30 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
