Old Tue, Sep-29-2009, 07:42:41 PM   #21
pish180
pish180's Avatar
Reputation: 0 pish180 is on a distinguished road
How many miles does the M3 Fuel filter last? e46
Jump to top pish180 is offline   Reply With Quote
Old Sat, Oct-03-2009, 10:00:26 PM   #22
Remi M.
Reputation: 0 Remi M. is on a distinguished road
Thanks to the OP for the DIY.
A few things to note:
If you forget to buy the copper washer (like me), or you mangle the one you bought. The copper washer that comes with a new oil filter has the same inside diameter and is a mm thicker, worked great.
If you have someone helping you pull the filter off the rear fuel line. Have them yank hard, instead of trying to twist it or continuously pull on it. And keep your face well away......(burning eyelids...not fun...)
Jump to top Remi M. is offline   Reply With Quote
Old Sat, Oct-03-2009, 11:08:31 PM   #23
GR///M3
GR///M3's Avatar
Reputation: 0 GR///M3 is on a distinguished road
Greece
remind me to put out the cigarette in my mouth b4 i open that drain valve.....he he
///M fan
Jump to top GR///M3 is offline   Reply With Quote
Old Sun, Oct-04-2009, 01:47:29 AM   #24
MarqE46
Wolverinium
MarqE46's Avatar
Reputation: 0 MarqE46 is on a distinguished road
thanks for the write up! might have to do this soon since I don't know if the previous owner(s) ever replaced the fuel filter.
Jump to top MarqE46 is offline   Reply With Quote
Old Sun, Oct-04-2009, 11:45:27 AM   #25
Reputation: 0 Obioban has a spectacular aura about
Nice!
Adding a link in the maintenance sticky!
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell
Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS
Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop
Selling: Suspensions, brakes, safety equipment, etc (ask away!)
Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool
Clearing out the garage: Used TCK camber plates, Imperfect fitment Scorza CSL trunk, CHEAP snow tires
Old Mon, Oct-05-2009, 04:46:28 PM   #26
Donovan
Reputation: 0 Donovan is on a distinguished road
I officially love you LOL
doing this at the weekend along with the springs and tires
Jump to top Donovan is offline   Reply With Quote
Old Mon, Oct-05-2009, 05:19:53 PM   #27
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
Thanks for posting a great step-by-step DIY.
I was already planning on doing this and had the parts around for a few weeks now. I did it over the weekend, but unfortunately I munged the rear fuel line connector in the process of getting it off the old fuel filter.
The single largest tip I can give: Be careful and certain of how you remove the rear fuel supply line. There is very little tolerance to move the plastic connector back into the fuel supply line to disconnect it. If it feels like you're forcing it or if its not going back, stop and try again. You have to push it straight back into the line. Any slight angle and it will either not release, or if you push it hard enough, you'll break it as I did mine.
The good news is its not catastrophic, but it was an expensive mistake. I ended up paying $48 for a new rear supply line to be shipped to me from Tischer, and I'm still waiting on the part to get my M3 back up and running.
If you do manage to screw it up and need a new one as I did, the rear supply part # is 16122229409
Jump to top Reach is online now   Reply With Quote
Old Mon, Oct-12-2009, 04:41:36 AM   #28
pish180
pish180's Avatar
DITTO
I just did mine this weekend. It was pretty easy. I just had some bastard fittings. Fitting 2 didnt want to come off with the quick disconnect. Almost broke the white release clip.
You will need to clamp the other hose that goes to the Fuel Pressure Regulator (FPR) that (not shown connected on the image above). It is on the Rt side of fitting 1. Fuel will continue to flow out if you do not pinch off the end (I used vice grips). It is connected using a hose clamp.
I used a table vice grip and a 19mm to remove the FPR from the fuel filter. Dont lose the crush washers either.
GL
Old Tue, Oct-13-2009, 10:55:48 PM   #29
aznbo187
MCLA
aznbo187's Avatar
Thanks guys, included some of your suggestions into the original post to make it more inclusive.
Old Wed, Oct-14-2009, 02:29:35 PM   #30
cheungms
cheungms's Avatar
Reputation: 0 cheungms is on a distinguished road
awesome DIY! Does it really matter if you buy a BMW crush washer or if you just go to your local autoparts store for one? what is the ID/OD?
thanks for the write-up!
sold:
2005 Lotus Elise
2005 BMW M3
Searching for E30 / E9x M3
Jump to top cheungms is offline   Reply With Quote
change, diy, filter, fuel
Discussing DIY Fuel Filter Change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
