Old Wed, Dec-30-2009, 02:41:49 PM   #41
soslower82
soslower82's Avatar
Reputation: 0 soslower82 is on a distinguished road
need to add this to my long list of upcoming maintenance.
Jump to top soslower82 is offline   Reply With Quote
Old Thu, Jan-21-2010, 11:10:25 PM   #42
20ducks
Reputation: 0 20ducks is on a distinguished road
Finished in little time thanks to PerkM3 for giving me the link.
Jump to top 20ducks is offline   Reply With Quote
Old Sat, Feb-27-2010, 04:04:17 AM   #43
MarqE46
Wolverinium
MarqE46's Avatar
Reputation: 0 MarqE46 is on a distinguished road
Great write-up! I will be tackling the fuel filter tomorrow
Jump to top MarqE46 is offline   Reply With Quote
Old Mon, Mar-15-2010, 08:03:47 PM   #44
neuralracing
Player making Plays!
neuralracing's Avatar
Reputation: 0 neuralracing is on a distinguished road
Puerto Rico
Is OEM the way to go for the filter? Or are their aftermarket alternatives that are proven to be better?
2002 CB on Black SMG - Dinan Stage 1 Software, Euro Rotors w/ Axxis
Jump to top neuralracing is offline   Reply With Quote
Old Mon, Mar-15-2010, 08:32:54 PM   #45
20ducks
Buying a fuel filter from an authorized BMW dealer gets you 2 years warranty. I don't know what an aftermarket filter costs nor do I know what warranty is offered. Your choice.
Old Sun, Mar-28-2010, 05:37:18 PM   #46
Highpower11
Highpower11's Avatar
Reputation: 0 Highpower11 is on a distinguished road
Just completed the DIY. A couple of added notes...
I used a 15/16 open-end wrench to hold the pressure regulator housing while I unscrewed the filter from the housing. I used a 3/4-inch open end wrench on the filter (can be used in place of 19mm if you don't have one as the dimensions are very very close) and used the two wrenches as leverage. Luckily mine was not on too tight.
The inlet section was a bit more difficult but the key here as the OP mentioned is to pull the white collar straight back and it will come right off. I had a drip pan at the ready as there will be some spillage from the filter once removed.
I reused the original copper washer, performed a leak test and all went well. During restart it ran rough for about 30-seconds then immediately smoothed out. I did pressurize the system as the OP advised (3-times) but still ran rough. I'll have to check later to see if it threw any codes.
Great DIY!
___________________
06 /// M3 ZCP, 6MT, Interlagos Blau Metallic \ M-Alcantara\ Volk RE30\ VMR 701 (winter)\ CDV delete\ ESS ECU Tune\ RPI Scoops\ BMC Filter\ Turner aluminum Race Pedals\ Rogue FR 10mm spacers\ Rogue RSM\ Vogtland Springs\
\ V1 Hardwire\ DICE/iPhone\ Smoked corners\ painted reflectors\ ZHP illuminated Alcantara shift knob\ HID fog's\ LightWerkz TFX\ Nav, Power seats & Sunroof delete\ Coming Soon: Euro Headers & Cats
Jump to top Highpower11 is offline   Reply With Quote
Old Wed, Apr-07-2010, 02:50:46 AM   #47
bongsau
bongsau's Avatar
Reputation: 0 bongsau is on a distinguished road
Just though id share my fuel filter change experience. The front was a mother to unscrew but some WD40 did the trick along with a pair of vice grips. The back of the filter was tricky too, i used a small open ended wrench to push the white clip back evenly. I managed to get fuel everywhere, rookie mistake. It was PITA for me but i got it done. After a rough start for about 30 seconds the car ran fine.
Jump to top bongsau is offline   Reply With Quote
Old Wed, Apr-07-2010, 12:03:54 PM   #48
MadeInPhilly
Reputation: 0 MadeInPhilly is on a distinguished road
Couldn't you just pinch the rubber fuel line behind the filter to avoid fuel spillage?
Jump to top MadeInPhilly is offline   Reply With Quote
Old Wed, Apr-07-2010, 05:38:48 PM   #49
GotM?
Admiral Douchington
GotM?'s Avatar
Reputation: 0 GotM? is on a distinguished road
I'm not sure you should need to. If you pull the fuse and start the car it dies and I think at that point de-pressurizes the line. I did it that way like the DIY suggests and then when I bled it barely any pressure was relieved as there wasn't much left. A little did come out when I finally got it all disconnected, about 1/4 a cup. However, getting the back of the filter off was an f'ing nightmare. For whatever reason it took me like 30 minutes and I was sure I had broken it but in the end it came off and the new one went on quickly and I had no leaks. Not sure if it will survive another replacement though without breaking the white clip in the back, it took a beating when I took the filter off.
- Chris
2004 Mystic Blue Metallic Convertible
Jump to top GotM? is offline   Reply With Quote
Old Fri, Apr-09-2010, 05:38:00 AM   #50
bongsau
bongsau's Avatar
Well i started the car twice like in the DIY and bled the filter for about 10 seconds and it was still full of fuel. Yes I could have pinched the lines but like i said rookie mistake.
change, diy, filter, fuel
Discussing DIY Fuel Filter Change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
