Old Sun, Jul-29-2012, 12:26:15 PM   #191
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Default Re: DIY: Subframe reinforcement epoxy/foam method. e46
Originally Posted by nuc1 View Post
I used two of the twin-tube cartridges using a tool I purchased from Grainger.
All bushings except the actual subframe bushings I replaced in my garage. Had to take the subframe and new bushings to a machine shop to have them replaced. Broke my cheap Harbor Freight press trying to replace them....
Mike
I'm sorry to go back to the question but before doing this I want to be very clear:
Did you use the 420mL BMW foam packs or the 220 ones?
It's unfortunate that the subframe bushings aren't easy to change. I'd like to DIY that but I guess it's not really doable.
Thanks!
Vanos hub / bolts DIY
Oil Pan Removal DIY
Foam subframe reinforcement DIY
Plastics Renewal DIY
Spacer DIY
ESS NA Tune Review
Tools:
-Shim kit -Timing tool -Engine support -Grainger foam applicator gun
DIY stuff
-Available in the NY/MA/NH area
Old Fri, Aug-03-2012, 01:03:21 AM   #192
nuc1
M-aholic
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
Thanks!
I don't remember. They fit the tool from Grainger that had the "5" in it. 400ml?
If you do it yourself, don't forget to plug the hole down on the bottom of the subframe by the rear mount....
You can DIY the subframe bushings if you have patience, a good drill and/or Sawzall..... Getting them out is doable - getting them back in is a ************.
Mike
02 TiAg/Black: Boosted street and occasional daily driver
95 Cosmos/Cosmos: S54-swapped track fun
Jump to top nuc1 is offline   Reply With Quote
Old Sun, Aug-12-2012, 03:49:44 PM   #193
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Mike
The "5" tool is the 420ml one, so I'll have to use 4 packs of that to do both sides.
Can you describe where that hole is? I was planning on just injecting from the top and ignoring those holes as I don't know where they are.
Thanks!
Oil Pan Removal DIY
Spacer DIY
ESS NA Tune Review
Tools:
DIY stuff
Old Sun, Aug-12-2012, 06:32:49 PM   #194
drunk hal
drunk hal's Avatar
Reputation: 0 drunk hal will become famous soon enough
Thanks!
Guess I need to get another "kit". I purchased my 2 - 420ml cartridge packs from someone who bought 4 but could only inject one per side before the foam started pouring out of the hole. Another guy reports the same thing. Now this guy reports he got 2 into a side and then a BMW master tech says you absolutely need 2 per side. I wonder why the results are varying like this? Different types of seam sealers being used?
Jump to top drunk hal is offline   Reply With Quote
Old Mon, Aug-13-2012, 01:55:20 PM   #195
drunk hal
drunk hal's Avatar
Went ahead and ordered another kit to be safe. If I don't use it I figure I can sell it and get most of the money back. Also ordered the Wurth Adhesiveflex seam sealer. Will probably be doing the work this weekend if the parts get here.
Old Mon, Aug-13-2012, 01:56:46 PM   #196
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
How are you planning on plugging the hole that's underneath?
Oil Pan Removal DIY
Spacer DIY
ESS NA Tune Review
Tools:
DIY stuff
Old Mon, Aug-13-2012, 02:37:04 PM   #197
drunk hal
drunk hal's Avatar
I already have the reinforcement plates welded on there.
Old Tue, Aug-14-2012, 01:22:06 PM   #198
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Ok. I haven't seen that hole while snooping around. I guess I'll have to try harder.
If you could take some pics of the foam DIY I would appreciate it, even if it's only 5-6. I'd like to get a better idea of where we're doing what, especially as we're doing both sides.
Thanks!
Oil Pan Removal DIY
Spacer DIY
ESS NA Tune Review
Tools:
DIY stuff
Old Tue, Aug-14-2012, 04:41:12 PM   #199
drunk hal
drunk hal's Avatar
Thanks!
You might not have that hole. The TIS specifically says "if" it is present, then plug it, which implies some models don't have it.
Also if I recall correctly the M3 has a different subframe floor than the standard coupe (which is the example used in the TIS), so I'm starting to think some of these guys reporting they could only get 1 - 420ml kit into each side are correct (at least in their case). Also there is the rumor that coupe started getting the vert floor at some point. These variations may explain why some are only able to get 1 cartridge injected per side.
Looks like I won't be doing the work this weekend. The place I ordered the Wurth seam sealer from doesn't have it, they just haven't updated their site. So I ordered it from the ebay.uk link. I got an email that is has shipped but I suspect it will take a week or so to get to Atlanta.
I will document the process. I think the most important thing will be keeping the cartridges up to temp so that they flow easily.
Old Tue, Aug-14-2012, 05:33:00 PM   #200
Nervous
Reputation: 0 Nervous is on a distinguished road
Looking forward to your writeup, drunk_hal! I already have the Wurth foam from ebay, but I need to order the structure foam kit(s) from thebmwpartstore.com (I have 330ci).
Jump to top Nervous is offline   Reply With Quote
diy, e46, epoxy or foam, method, reinforcement, subframe
Discussing DIY: Subframe reinforcement epoxy/foam method. e46 in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
