Old Sat, Oct-17-2009, 07:58:53 AM   #11
jvit27
TEAM OEM
Reputation: 0 jvit27 is on a distinguished road
Originally Posted by fitchesbass View Post
and Jt designs.
JTD's won't work with Koni's.
Jump to top jvit27 is offline   Reply With Quote
Old Sat, Oct-17-2009, 08:18:40 AM   #12
Synenergy52
Reputation: 0 Synenergy52 is on a distinguished road
Thanks for the picture!
Update: I ordered a new RSM and two oem washers. Should be here Monday. I'm obsessing about whether or not it's safe to drive my car. Yes worst case scenario my shocks pop out on a bump. Whats holding the pressure of the shocks? it seems without that cupped washer, it's simply being held in place by the rubber bushing? If that's the case I may have weakened the drivers side RSM. I've been driving my car very gently lately in fear the shocks will push the bushings out. I won't dare put my top down until I resolve this. I can only imagine what those rear shocks would do once they shoot up through the convertible well with the top folded inside.
Originally Posted by gripenM View Post
the one on the right is a proper rsm set up, missing in the picture though is
another cupped washer that goes on top of the RSM as well
i went with OEM, but i used E46 M3 RSM with Z3 reinforcement plates (gold things).
feels very good, it's quiet and i've had it for 16,000km and i like it so far.
Jump to top Synenergy52 is offline   Reply With Quote
Old Sat, Oct-17-2009, 08:24:14 AM   #13
Synenergy52
btw gripenm, amber on estoril looks great. i think i want to switch back.
Old Sat, Oct-17-2009, 08:34:13 AM   #14
falciott
falciott's Avatar
Reputation: 0 falciott is on a distinguished road
That's why the top and bottom washers are needed, they compress the bushing, otherwise if the rubber is allowed to stretch in either direction, it would slide out of the metal plate like a snail out of its shell.
1997 Arctik Silver M3,80K miles.
Clear lights, Corsa RSC36, DJ Auto with TFX retrofit, Illuminated ZHP knob,Brushed aluminum look console and bits,Perforated 3 spoke steering wheel, Becker Grand Prix with bluetooth, Motion sensor HD dash cam, BMW Homelink, Keyless entry, RE short shifter,CSL reps, Mason strutbar,Reverse sensors, Automatic rain sensing wipers, everything else? Stock!
Jump to top falciott is offline   Reply With Quote
Old Sat, Oct-17-2009, 11:11:26 AM   #15
JT Design rear shock mounts work fine with Konis. I ran them for 3 years with Koni SA plus H&R Sports.
The only Konis they do not fit are the top adjustable rears that come with or are an added cost option on coilover kits. When I upgraded my suspension to TCK coilovers which have the top adjustable rears with the thicker shaft, I used the TCK RSMs (which are made by JTD) although JTD said I could modify the standard JTD mounts as an alternative.
Old Sat, Oct-17-2009, 11:24:44 AM   #16
The cupped washer limits upward travel. The last 3 inches of the shaft is thinner than the rest of the shaft. The thin part goes through the cupped washer but the thick part cannot. Then once the thin part is through the cupped washer and through the RSM body and RSM bushing and into the trunk area of the car, a washer and nut go on top to hold the whole assembly in place. To allow the RSM bushing to cushion the shock action, the hole for the shaft in the center of the RSM body has to be bigger than the shaft diameter. Thus, with no cupped washer, the shaft can poke right through into the trunk. It might take a few miles but it will happen.
If this has happened, I would probably buy a new RSM unless I could assure myself that there was no damage to the RSM bushing or the hole in the RSM body. Some aftermarket RSMs can be easily disassembled, like the JTD, so you could make this complete inspection. Not sure if you can get yours apart but would assume it is possible.
2nd, brand, month, mount, popped, rear, shock
Discussing Need help. Popped 2nd brand new rear shock mount in a month. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
