Old Mon, Mar-08-2010, 11:56:53 AM   #41
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
Reputation: 0 M302_IMOLA is on a distinguished road
Originally Posted by Tchleung View Post
As I posted in another Magnaflow thread regarding the tip sagging:
Everyone has problems with this as I did too. It wasn't really a big deal tho, I shimmed my passenger mount to the body by about 1"(yes that much) to the point where the stud coming off the body just peeks out of the fastening nut. This aligned it almost perfect, I then just loosened the exhaust band clamps and rotated the muffler upward to fill in the gap left between the tips and OE diffuser and mines came out almost perfect.
As for the V-Brace, I shimmed that down by about 3/4" and the two braces in the middle(one of them bolts to the exhaust via rubber mounts), I spaced those down about 1/4" to pull it down and also put a washer in between the rubber mount and the bracket to try to lift it a bit higher in the tunell.
Everything fits flawless after all that tweaking. Overall the fitment was **** IMO. I've had cheap ebay stuff fit better. But for the price and what you all get I cannot complain too much, I was just surpirsed at how bad the system fit.
I'd take a pic of the alignment... But it's pretty self explanatory so.
Even over the stock system.. I can tell there is some low end torque loss, but mid range all teh way up is definantly faster. I know exhausts on these cars are not supposed to gain much, but it's pretty apparent when I can spin the tires alot more everytime now then before, even with a passenger.
Thank you for the tips (no pun intended)!
02' IR/IR
Current Mods: Painted front reflectors, matte black fender gills, carbon fiber roundels, Depo smoked corners, 19" Ruff Racing wheels wrapped in Hankook Ventus V12's (245/35F & 275/30R), Status Gruppe coilovers (7K/8K), RE RSM's, Powerflex RTAB's & FCAB's, DICE, CSL Rep Diffuser, CF Hamann Rep Lip, Magnaflow exhaust, Ebay headers, Streamline filter, Afe elbow, RPI scoops, ZHP knob, and EE LED tails.
WTB: OEM Front strut bar, Evolve stage II tune, 4.10's, and CF CSL rep Bootlid
Jump to top M302_IMOLA is offline   Reply With Quote
Old Mon, Mar-08-2010, 05:46:17 PM   #42
Subw00er
Subw00er's Avatar
Reputation: 0 Subw00er is on a distinguished road
About the gaskets, do you use exhaust sealant too (that brush on stuff that hardens later), or just new gaskets? I bought two new ones for the front, they just look like big sculpted lead washers, which I guess will crush in there and give a good seal?!
Mod finished and now in production!: Bates Custom Valvetronic Exhaust: http://www.m3post.com/forums/showthread.php?t=253661
Jump to top Subw00er is offline   Reply With Quote
Old Mon, Mar-08-2010, 10:31:30 PM   #43
Tchleung
Reputation: 0 Tchleung is on a distinguished road
When you mate the two flanges together with the exhaust gasket it will be quite apparent how much the gasket will compress when you see the gap between the flanges even with the gasket already fully touching both flanges before even tighening.
02 Carbon Black M3 6MT
456whp/312wtq @ 8psi, No #'s yet at 9.5psi
4.10 / Headers / ESS VT2-550+ / Tuned by Evolve
Jump to top Tchleung is offline   Reply With Quote
exhaust, installing, magnaflow, tips
Discussing Tips for Installing a Magnaflow Exhaust? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
