Old Wed, Sep-22-2010, 02:23:39 AM   #41
M3feuer
Reputation: 0 M3feuer is on a distinguished road
Would appreciate some education on what comprises the VANOS assembly. Reason being, I had to replace the entire VANOS unit as a result of breaking one of the "teeth" on the camshaft gear which in turn completely compromised the VANOS system. I was fortunate that the broken part (tooth?) didn't get sucked in the timing chain and blow the engine. Anyways, 4 weeks removed from a very expensive repair I am getting a P0010 error code. Question is: If the solenoid valve and gasket's are all part of the VANOS unit (~$4k unit), is this error perhaps simple as a fault CPS sensor?
Jump to top M3feuer is offline   Reply With Quote
Old Wed, Sep-22-2010, 02:51:45 AM   #42
sddynamix
sddynamix's Avatar
Reputation: 0 sddynamix is on a distinguished road
Is P0010 Intake Camshaft Vanos Position Control?
I'd go right back to the shop that fixed it and the timing checked.
The VANOS system is comprised of two basic components - the Actuator (the part that has the two pistons that moves the camshafts), and the Solenoids, which fire the pistons (Advance/Retard).
You could be getting that code either because a) the motor is incorrectly timed, and your cam position sensor isn't reading what the DME is expecting (usually about 60 degrees on the intake side at idle), b) your VANOS actuator is not advancing/retarding your cams consistently, or c) you have a faulty sensor.
Frankly its easy to diagnose with a computer (bad sensors give inconsistent/drop out readings, otherwise a GT1 Vanos test will tell you whether or not the actuator can move the cams through their full range of motion). Take it back to the shop you had this work done.
Jump to top sddynamix is offline   Reply With Quote
Old Mon, Nov-15-2010, 06:06:03 PM   #43
BimminLSB///M3
Reputation: 0 BimminLSB///M3 is on a distinguished road
I have oil leaking underneath and around this vanos unit. Is it possible that it's from the solenoid o rings? If so, can I just remove my solenoid, replace gaskets and reinstall with the same bolts and solenoid? I don't have any codes and am not lacking performance, just leaking oil. The dealer thinks its the head gasket..
2001 BMW M3, Laguna Seca Blue
Options: 6spd, Sun Roof, HK Sound, Cold Weather Package, Xenons, Nappa Leather.
Mods: 19" CSL Wheels, CSL Brake Kit, RE RSM's, 35% Tint , Hardwired V1, Alarm, Bluetooth, Black Grills, Painted Reflectors.
Next Mods: SS Race Exhaust, Suspension.
Jump to top BimminLSB///M3 is offline   Reply With Quote
Old Mon, Nov-15-2010, 06:24:21 PM   #44
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb
Originally Posted by BimminLSB///M3 View Post
...can I just remove my solenoid, replace gaskets and reinstall with the same bolts and solenoid?..
Yes, the sealing plate is around $15 and takes about 15 mins. to replace. The mounting bolts should be tightened evenly to 5 Nm.
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Tue, Nov-16-2010, 04:07:18 PM   #45
BimminLSB///M3
Thank you, has anyone heard of or seen any posts about the solenoid being the source of an oil leak? I am unable to find anything through searching the forum. Here is my post with pictures:
http://www.m3forum.net/m3forum/showthread.php?t=319653
Old Tue, Feb-01-2011, 05:39:43 AM   #46
[}emo1337
[}emo1337's Avatar
Reputation: 0 [}emo1337 is on a distinguished road
Default Re: DYI: Replace VANOS Solenoid Valve on 2003 E46 M3 (Part 1...)
Isn't 5 Nm about 44lbs of torque?
Sounds like a lot even though the OP said its light
Jump to top [}emo1337 is online now   Reply With Quote
Old Tue, Feb-01-2011, 01:20:21 PM   #47
vcarter911
vcarter911's Avatar
Reputation: 0 vcarter911 is on a distinguished road
Yikes - no. Here is a conversion table for you. http://www.cleavebooks.co.uk/scol/cctorq.htm
2003 BMW M3
6spd, 19's, HK, CWP, UUC Rtabs & CTRL arms, Comp suspension & sway bars, Euro cross drilled Rotors, RP fluids.
Previously owned German:
1972 BMW Bavaria 3.0
1976 BMW 2002
1987 VW GTI
1991 VW Jetta 2 door
1992 VW GTI
1997 Audi A8 Quattro 4.2
2005 VW Jetta TDI
Jump to top vcarter911 is offline   Reply With Quote
Old Tue, Feb-01-2011, 06:56:27 PM   #48
Alchemist753
2003.07 E46 M3
Reputation: 0 Alchemist753 is on a distinguished road
5 newton meter = 3.68 pound foot
Go very easy on those bolts.
Jump to top Alchemist753 is offline   Reply With Quote
Old Wed, Feb-02-2011, 03:11:38 AM   #49
[}emo1337
[}emo1337's Avatar
thanks guys, it seems I was looking at the lb per inches instead of feet
Old Wed, Feb-02-2011, 05:37:29 PM   #50
///NNM
previously: milovanov
///NNM's Avatar
Reputation: 0 ///NNM is on a distinguished road
Russian Federation
i didn't have any oil leak before at over 150k miles, my bolts were tightened around 10 f*lbs, so i tightened them the same way... i will post updates if i get a leak or not.
Evolve Alpha-N | SuperSprint Headers | MS: Elbow | 4.10 | TMS: Pulleys, Camber Plates & Arms, Solid Diff mounts, Studs, Front/Rear Subframe Kits | ACS Strut bar | PF RTABS | UUC: SSK3, DSSR, tranny mounts, SS clutch, brake lines | H&R Front Sway | ST coils v1 | 18" BBS RCJ | Custom Vibrant Performance Exhaust
YouTube DIY Videos Sister 98 M3 2dr; Wife 04 X3 3.0
Jump to top ///NNM is online now   Reply With Quote
2003, dyi, e46, part, replace, solenoid, valve, vanos
Discussing DYI: Replace VANOS Solenoid Valve on 2003 E46 M3 (Part 1...) in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
