Old Wed, Nov-04-2009, 09:48:33 PM   #1
bsewell
Reputation: 0 bsewell is on a distinguished road
Default Differential MESS
I had very little diff fluid left when I changed my gear oil the other day. About 500 to 600 ml. And this picture shows what a mess it is under there. Is this just a seal issue or something bigger.
Jump to top bsewell is offline   Reply With Quote
Old Wed, Nov-04-2009, 10:55:30 PM   #2
J02 M3
1,2,6th
J02 M3's Avatar
Reputation: 0 J02 M3 is on a distinguished road
Probabaly a pinion seal. Looks a little rough though, has something hit the bottom of it? Hopefully its not cracked.
02 M, Gloss black side gills, Tein S-Tech's,
DBA brakes, 245/35/19 & 275/30/19.
Jump to top J02 M3 is offline   Reply With Quote
Old Wed, Nov-04-2009, 11:45:39 PM   #3
bsewell
Looks like I ran over something. I have no memory of hitting anything significant. I guess I should clean it up a bit and look for cracks?
Old Thu, Nov-05-2009, 12:02:08 AM   #4
///M3THOD
///M3THOD's Avatar
Reputation: 0 ///M3THOD is on a distinguished road
Attachment 108241
More than likely thats a seal leak, I have had one before, it comes out the front like that, you need new gaskets and fluid.
'04 TiAg ///M3 SMG vert
| JVT headers || AP section 1 || KSport || BMW Motorsport 4.10 || Depo Smoked Corners || Custom ski pass Alpine Type R|
| UUC RTAB's/FCAB's/tranny mounts || Auto Technik matte grills || Orion V2's || Anthracite Powdercoated OEM ZCP's || EAS monochrome badges |
Jump to top ///M3THOD is offline   Reply With Quote
Old Thu, Nov-05-2009, 12:08:41 AM   #5
bsewell
Any idea what the seal part number or description might be? It's not
33 10 7 510 289 - Rear Differential Output Shaft Seals (2 per car) is it?
Old Thu, Nov-05-2009, 12:57:45 AM   #6
kaiv
SoCal vanos/valve specialist :D
France
Am I the only one who expected to see some chewed up gears by clicking this thread? ^^
AW S65 E92 6MT
past: AW S65 E90 6MT- LSB S54 E46 6MT- JB S52 E36 5MT
Kaiv's SoCal Feedback! [M3Forum] [iTrader] [Bimmerforum]
Old Thu, Nov-05-2009, 05:22:13 AM   #7
indica88
Reputation: 0 indica88 is on a distinguished road
Pinion seals on the rear differential really should not leak that much. You should have the vehicle looked ASAP. You may also have rear axle seals that leaking also. Do not drive the Liberty too long with low fluid. Rear differential carrier and pinion bearing are very expensive to replace. Rear pinion seals usually run about $130.00 or so. They are easily changed in about an hour.
professional cv template
diesel engine parts
Jump to top indica88 is offline   Reply With Quote
Old Thu, Nov-05-2009, 01:51:09 PM   #8
bsewell
I'm looking for this on realoem.com is this part number 33121213949 shown here
Old Mon, Apr-26-2010, 07:55:17 PM   #9
bimmer777
I drive an AWD Turdbro
bimmer777's Avatar
Reputation: 0 bimmer777 is on a distinguished road
Ukraine
Bump this, didn't want to start a new thread. I have the same exact problem (main input shaft leaking) and want to make sure I get the right seal. Is it #7 (part#33121213949) from the diagram in the above post?
Other items I will change:
1. Guibo since I will have to drop the prop shaft.
2. Diff bolts - swap out old fully threaded ones for new ones where the thread does not go up all the way to the hat.
Anything else I should look for? The output seals are not leaking so I don't want to touch them. Subframe was already welded.
"Good drivers have dead flies on the side windows" - Walter Röhrl
Jump to top bimmer777 is offline   Reply With Quote
Old Mon, Apr-26-2010, 08:38:12 PM   #10
bsewell
I never pursued the seals. I just replaced the fluid. Now that it's warm weather, I need to take a look again and see what the level is, but it's on my list to replace the seals.
differential, mess
Discussing Differential MESS in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
