Old Tue, Apr-27-2010, 12:04:20 PM   #11
bimmer777
I drive an AWD Turdbro
bimmer777's Avatar
Reputation: 0 bimmer777 is on a distinguished road
Ukraine
Mine has been "sweating" for a while and last time I had to top off the diff. I think it is finally time to replace it.
Can anyone confirm the part number? Somebody must have done the swap!
"Good drivers have dead flies on the side windows" - Walter Röhrl
Jump to top bimmer777 is offline   Reply With Quote
Old Tue, Apr-27-2010, 12:09:13 PM   #12
Hu///mmell
Hu///mmell's Avatar
Reputation: 0 Hu///mmell is on a distinguished road
I have the same problem on my car. It's the pinion seal. I need to get it fixed.
Jump to top Hu///mmell is offline   Reply With Quote
Old Tue, Apr-27-2010, 01:48:57 PM   #13
neuralracing
Player making Plays!
neuralracing's Avatar
Reputation: 0 neuralracing is on a distinguished road
Puerto Rico
Originally Posted by kaiv View Post
Am I the only one who expected to see some chewed up gears by clicking this thread? ^^
+1
2002 CB on Black SMG - Dinan Stage 1 Software, Euro Rotors w/ Axxis
Jump to top neuralracing is offline   Reply With Quote
Old Sat, Jul-31-2010, 12:30:09 AM   #14
jedi_k
Reputation: 0 jedi_k is on a distinguished road
I'm in the same boat. Any DIY?
Jump to top jedi_k is offline   Reply With Quote
Old Sat, Jul-31-2010, 12:45:48 AM   #15
GRKM3
GRKM3's Avatar
Reputation: 0 GRKM3 is on a distinguished road
upgrade to 3.91 while you're at it.
2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius
Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor...
5D Mark III | 24-70 2.8 IIL | 17-40 4L | 50 1.8II | 580EXII
Jump to top GRKM3 is offline   Reply With Quote
Old Sat, Jul-31-2010, 01:40:14 AM   #16
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
I just happen to have a couple in front of me. Putiing them in a couple of weeks.
33 10 7 510 289 seal and clip.
Jump to top hogger453 is offline   Reply With Quote
Old Wed, Mar-09-2011, 03:38:13 AM   #17
cw
Reputation: 0 cw is on a distinguished road
Default Re: Differential MESS
Is the driveshaft loaded when connected to the diff? Or is it just plug and play?
Jump to top cw is offline   Reply With Quote
Old Wed, Mar-09-2011, 02:26:46 PM   #18
flow350
Reputation: 0 flow350 is on a distinguished road
Originally Posted by bimmer777 View Post
Bump this, didn't want to start a new thread. I have the same exact problem (main input shaft leaking) and want to make sure I get the right seal. Is it #7 (part#33121213949) from the diagram in the above post?
Other items I will change:
1. Guibo since I will have to drop the prop shaft.
2. Diff bolts - swap out old fully threaded ones for new ones where the thread does not go up all the way to the hat.
Anything else I should look for? The output seals are not leaking so I don't want to touch them. Subframe was already welded.
You should also replace the center support bearing of the driveshaft while you have it out. The part number is: 26122282495. Also, you have to drop the exhaust for this job. You should use new gaskets for the exhaust. You will need 2 flat gaskets: 18307830674 and 4 gasket rings: 11627830668
Jump to top flow350 is offline   Reply With Quote
Old Wed, Mar-09-2011, 02:28:07 PM   #19
flow350
Not sure I understand your question... But, I think you are asking if there is any tension on the driveshaft. There is not any tension on the driveshaft unless the car is on the ground and under power.
Old Wed, Mar-09-2011, 02:48:40 PM   #20
bimmer777
bimmer777's Avatar
Ukraine
Thread is from a while ago and i did this last spring, but thank you for the advice. The job was flawless, diff is perfect now. I did replace gasket rings and all the exhaust bolts as they were getting pretty corroded. Didn't replace the flat gaskets or the center support bearing. The bearing didn't look bad and only had 50k miles on it, do these go bad? I can always replace it as part of my spring maintenance as I plan on replacing the Guibo among other things.
differential, mess
Discussing Differential MESS in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
