#11 |
![]() ![]() ![]() ![]() ![]() ![]() Location: Switzerland
I had a tiny leak, not sure if it was at the same place. BMW re-torqued down the bolts and that was the end of it. Not sure I would do this myself if I didn't know what the correct torque should be, as over tightening could have other consequences.
#12 |
Looks like its sweating... No big problems but I would have the dealer replace the seals.
#13 |
CF Junkie 4 Life!
![]() Location: Honolulu, HI
I didn't know this was common.
I didn't see any leaks on my axle shafts-to-differential yesterday when I was taking out the suspension.
![]() Special Thanks to: Simon and Jeff |
#14 |
I am having the same problem, and small spots of diff fluid are on the garage floor. Would the dealer repair this under cpo, and would they say anything if the car had different wheels and coilovers?
#15 |
I drive an AWD Turdbro
![]() Location: NYC
Same problem here, no drips yet. Check oil level on the regular basis and it is actually always full. I as under the impression that this is pretty common and not really a cuase for concern unless oil level in diff goes down.
"Good drivers have dead flies on the side windows" - Walter Röhrl |
#16 |
![]() Location: tempe
I had what sounded like a brake caliper hanging up this morn on the way to work. Put the car up on the lift this morn to look at it at my shop, while i was looking at the rear brakes i noticed the exact same thing on my car. Those pics look like they could have been taken under my car, sounds like a common thing.
#17 |
Great White
![]() Location: Long Island, NY
*UPDATE*......Well I took her in for the appointment today and the dealer just called me and said they are replacing the diff seals and that obviously means a diff flush as well. All this for $50, which is my deductible on my CPO warranty
......My goal is to have all new parts on the car by the time the warranty expires ......Im kidding about all that but seriously if given the oppurtunity to get the CPO warranty, its a no brainer........
2005 Coupe AW/BLK/SMG/LOADED Last edited by skelzy; Tue, Nov-17-2009 at 12:56:40 AM. |
| aboutpics, concerned, drive, leak, pics, rear, shaft |
