| Forced Induction (F/I) Discuss the ever growing F/I options here! |
Shhh..my foot is sleepin on the gas
![]() Location: Planet Earth
hey has anyone messed up their engine or ran into any problems with nitrous ...? (explain what type of set up it was as well)
Any one familiar with a local shop in NOVA to do a install ??
![]() HKS GTS8550 Stage II *SuperSprint*Aeromotive Clutch Masters*4.10*Rogue Engineering KW3*H&R*Ground Control*Euro rotors*SS lines 42 Design*Vorsteiner*Bimmian*Apex*//M-Alcantara 507WHP @ 8400rpm-11.2psi . **Need a Expert BMW tech in the DMV Pm Me**
hmmm.......
Scott@Radar-Mirror.com
![]() Location: Dallas
Nitrous is rarely used on the S54, which probably explains the lack of reply's to your thread. fwiw.
CLICK HERE FOR BMW REAR VIEW MIRROR REPAIR www.Radar-Mirror.com Scott@Radar-Mirror.com |
#4 |
Nitrous rarely used on S54???? That sh$t is funny! The S54 is the perfect engine for nitrous...and many many people use nitrous on M3's. To the OP....your S54 engine has a forged crank and an iron block. If your boosting with a SC or turbo and using Nitrous, I would consider forged pistons and rods. If you set up your system properly, you won't have any problems! The worst thing you can do, is go lean. The reason your not getting many responses to your question is not because lack of use
it's because people are having success. Anyone who did fry pistons or broke rods, probably won't admit it because they were stupid and know it. I'll include a description of my setup below.http://www.bimmerfest.com/forums/sho...893&highlight= I have a ZEX wet 75 shot with 10lb bottle, ZEX remote bottle opener, ZEX bottle heater, ZEX traction control...which allows what rpm and gear for activation as well as max rpm nitrous shut off. I have a dual ZEX purge kit with red led lights. The purge allows you to purge air through the line so that activation occurs with pure nitrous. Race comp AFR and nitrous guage which I feel are very important. ZEX nitrous systems will automatically adjust fuel ratio depending on what the bottle psi is. The bottle heater is critical for maintaining at least 900 psi for a more dramatic nitrous punch! On my switch panel, the red push button is the purge, the blue guard switch is bottle heater, the red guard switch is the nitrous arm, and the window type switch is to open my nitrous bottle remotely from the comfort of my seat. It's not a perfect looking setup, but I think it looks nice. I had the work done professionally with custom install of switch panel and guages out the door after taxes for $2700. A little expensive for a nitrous setup....but you can easily spend more buy the way nitrous and superchargers compliment each other nicely. Nitrous dramatically cools the intake charge during hot summer months and superchargers love cold weather when nitrous bottles are difficult to heat to optimum psi Attached Thumbnails |
#5 |
great input thanx
#6 |
anyone else bump
#7 |
ॡحمدॡ
![]() Location: QATAR
There is a Nitrous FAQ thread up in this section
check it out .
Euro 01 IR/IR ///M3 113K miles|281rwhp on DD ![]() ^ SOLD^ Engine: aFe drop in filter, SS race exhaust |Drivetrain: AS Ultimate SSK w/ UUC DSSR, ZHP shifter knob, GSP clutch pedal. Suspension : AST 5100's 600/750 w/ Vorshlag camber plates, PF RTAB's, RE RSM, UUC adjustable rear camber arms, TMS reinforcement kit & endlinks |Braking: Cool Carbon, StopTech SS lines| Exterior: Alufelgen SF-71's, VORS(1x1) CSL bumper, trunk and diffuser,OEM rear LED's, blackout front grills, CF side grills , smoked corners and side signal lights, TFX conversion, Umnitza 4300K V2's angle eyes, Euro wide convex mirrors| Interior: US spec trunk release button, OEM alcantara boot, OEM alum pedals. |
#8 | ||||
M-aholic
![]() Location: South Floriduh
EDIT: Reread my post and saw if could be taken as a dig on fr8tdog. Not trying to be a dick, just adding some info. No offense meant to anyone. Mike
Have fun. Mike
02 TiAg/Black: Boosted street and occasional daily driver 95 Cosmos/Cosmos: S54-swapped track fun Last edited by nuc1; Fri, Nov-27-2009 at 02:00:32 PM. |
#9 | |
its always the great stories i wanted to know some more before installing it
#10 |
![]() Location: Kirkland
I'm running a 100 shot on an S52 with M50 intake..good stuff here. AFR's around 11.0-11.5 @1000psi bottle
| nitrous, nos, nos installation, nos problems, problems |
