Old Tue, Dec-22-2009, 10:21:21 PM   #1
ShafferMD
M3 Enthusiast
Reputation: 0 ShafferMD is on a distinguished road
Default Tire Rub - Passenger Side
Had new tires fitted over a month ago...Upsized to the next alternative per MadRussian's recommendations. Currently running 245 / 275 x 18" combo.
Upon install, no issues with rubbing at all. Great fit...until today!
It appears the passenger side lower spring perch is barely rubbing on the inside edge of the tire. Sounded like a wicked engine knock at first, but slowed with vehicle speed. I thought there could have been a large stone or something in the tread, but upon investigation found interference with the spring perch to be the culprit.
I lowered the tire pressure 10psi just to get it home (~2.5 miles) without rubbing.
My question is...can the spring perch rotate? I am charging my camera batteries so I can post pics. The driver side looks fine, no issues at all. The passenger side is waay too close, but appears that if the spring perch would rotate then it would clear just like the driver's side.
Again, pics will be posted ASAP.
Please let me know your opinions...
SOLD:
2003 6MT ///Carbonschwartz Metallic : Black Nappa : Premium Package : Cold Weather Package
PERFORMANCE: 245/275 PS || CDV Delete || Clutch Stop || BMW SSK || RE RTAB's || APPEARANCE: Invisibulbs || AC Schnitzer Pedals || Custom Toolkit w/ M3Forum Decal || Painted Reflectors || 55W Xenon Matched Fogs CONVENIENCE: Eurotray || Dynavin V4 DVD/NAV
Ask me anything about Powdercoating!
PM me for Metric Clutch Stop sourcing
Jump to top ShafferMD is offline   Reply With Quote
Old Tue, Dec-22-2009, 10:46:33 PM   #2
slammine46
SLAMMINE46
Reputation: 0 slammine46 is on a distinguished road
mine was rubbin a little with 20s i raised it by loosening the bottom strut bolt and pushing it up a quarter of n inch on both sides hope this helps ......your camber could also b a little off
Jump to top slammine46 is offline   Reply With Quote
Old Tue, Dec-22-2009, 11:18:32 PM   #3
ShafferMD
M3 Enthusiast
Default Willing to try...for now?
Did the strut try to push down when you loosened the lower strut clamp bolt? Unless someone else has some feedback, I am willing to try this fix for now.
I think that if I had about another 32nd wear on my tires the rub would be gone...but I am concerned as to what made this happen...
The rub is so slight that it has only worn the paint off the lower perch and you can't even notice anything cutting or witness marks on the tire.
I measured the distance from the bottom of the strut to the lower strut clamp and there's only about .004" difference between passenger and driver sides. The real problem appears to be the rotation of the oblonged lower strut perch and the offset bend in the perch itself. When comparing to the driver's side, the rotation of the oblonged offset is @ about 5 o'clock when viewed from tire center. This position places the offset off the tire. When viewed from the passenger tire center, the offset is @ about 7 o'clock...this puts the kinked offset over the outside wall of the tire.
I am not sure if this all makes sense to you, but the pictures in my first post go a long way in helping to define my problem.
Please let me know if there are any other solutions other than raising my strut...I fear that will change things (perhaps negatively) other than just providing clearance.
SOLD:
Old Wed, Dec-23-2009, 12:25:34 AM   #4
ShafferMD
M3 Enthusiast
Default Anybody?
Bump...nobody has any insight?
SOLD:
Old Wed, Dec-23-2009, 01:28:07 AM   #5
lsb
lsb's Avatar
Reputation: 0 lsb has disabled reputation
Default r/f spring mount
I did read that someone had the same problem is you and i. He wrote in his post that he did in fact rotate the pass. side lower spring mount.
It would involve removing the strut assembly and roving the spring. It looks as if you would need to knock it up and off, you could then rotate and reinstall.
I ended up decreasing my front tires from 265/35/19 to 235/35/19 w/20mm spacers until i receive my (new to me) struts from the rebuilder.
Jump to top lsb is offline   Reply With Quote
Old Wed, Dec-23-2009, 04:00:42 AM   #6
///M.EngT
Reputation: 0 ///M.EngT is on a distinguished road
I love your sig'
Jump to top ///M.EngT is offline   Reply With Quote
Old Wed, Dec-23-2009, 10:15:36 PM   #7
lsb
lsb's Avatar
^^^ thanks, looks like i am in suspended animation.(zero roll)
Old Tue, Jun-08-2010, 02:03:54 PM   #8
gregoryp
Reputation: 0 gregoryp is on a distinguished road
Default Same Problem
I was looking at the tread wear on my front tires and noticed that my right front spring perch is also super close to the tire. It looks like if I got new tires they would rub. Currently the right front has more wear on the inside of the tire than the left side, so maybe my camber is off a bit. But the step in the perch is definatley in a different position than the left side. Can you actually rotate the spring perch?
Jump to top gregoryp is offline   Reply With Quote
Old Tue, Jun-08-2010, 02:31:56 PM   #9
gregoryp
I was looking at the parts diagram on the Real OEM site and it looks like you could just rotate the whole strut by loosening the clamp where it attaches to the knuckle. Anyone done this? I might pull it apart and look at it tonight.
Old Tue, Jun-08-2010, 04:50:23 PM   #10
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
We have spacers specific for the E46 M3 available below...
Click HERE to order or for more information.
Please let me know if you have any questions! Feel free to shoot me a PM or email.
Best,
Joe
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
sales@ecstuning.com | customerservice@ecstuning.com
Jump to top ECSTuning is offline   Reply With Quote
passenger, rub, side, tire
Discussing Tire Rub - Passenger Side in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
