Old Thu, Dec-24-2009, 11:39:45 PM   #1
jateshk
jateshk's Avatar
Reputation: 0 jateshk is on a distinguished road
Default cheapest place to get ODB2 scanner?
Need to purchase one. Which one is compatible. Does it have to be Can-bus?
ebay?
Jump to top jateshk is offline   Reply With Quote
Old Fri, Dec-25-2009, 01:55:53 AM   #2
deilenberger
deilenberger's Avatar
The cheapest one you can find that will connect with the M3 ECU. They ALL do the same thing - read a numeric code. P0000-P1000 are generic OBD-II codes, P1001-1999 are manufacturer specific codes, which you'll have to use a lookup table to find out what they mean for our cars.
DO make sure you have a return option if it fails to connect to our ECU - the M3 is a bit touchy that way. And no - you don't need CAN. OBD-II doesn't use CAN.
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Old Fri, Dec-25-2009, 05:06:02 AM   #3
MattMan
Modded
MattMan's Avatar
Reputation: 573 MattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond repute
If you need it temporarily, you can borrow one at AutoZone.. read the codes.. and return it in 90 days.
MattMan
Jump to top MattMan is offline   Reply With Quote
Old Fri, Dec-25-2009, 05:33:25 AM   #4
Junger
Junger's Avatar
Reputation: 0 Junger is on a distinguished road
Purchased Actron CP9185 OBD II reader from EBAY for $120 (NEW) and works great for my M and Audi.
All the time and money I spent on my cars; I would do it all over again. /// M POWER
Jump to top Junger is offline   Reply With Quote
cheapest, odb2, place, scanner
Discussing cheapest place to get ODB2 scanner? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
