Old Fri, Jan-08-2010, 03:55:24 AM   #11
Donovan
Reputation: 0 Donovan is on a distinguished road
Hrmmms
Jump to top Donovan is offline   Reply With Quote
Old Fri, Jan-08-2010, 03:56:11 AM   #12
emax13
emax13's Avatar
Reputation: 0 emax13 is on a distinguished road
Most name brand gas contains detergents.
I would not use unless you had to do a few fill ups at no name stations.
'06 CB/IR w/SMG/NAV/HK/Eibach/19" BBS RGR/Hankooks
Jump to top emax13 is offline   Reply With Quote
Old Fri, Jan-08-2010, 03:59:08 AM   #13
lorkar
Ulitimate Fahrmaschine Spezialist
lorkar's Avatar
Reputation: 0 lorkar is on a distinguished road
Norway
Originally Posted by RedM3/4 View Post
Re: self-cleaning injectors: Ovens have been self-cleaning since the 70s, tranny's have lifetime oil, and I've got some swampland in FL.
I use Techron from time to time. It is the product sold by VW, BMW, and others, and I've had *amazing* results from it in a couple of instances.
If you over use it, I know one very respected mechanic that claims his own over-use caused leaking injectors. I think a bottle every 10k is good, but check the bottle, AND, this is NOT a replacement for fuel filter changes or any other normal maint.
ADS
I've been working on Cars for a living since the early 80ies. The only failed injectors I've seen are ones that sat for a very long time. Those in use, U can count on one hand the amout of actual failed injectors I had to replace because it was clogged.
If you want to spend money on injector cleaner knock yourself out. I challenge that money is better spent on beer.
19"SSR GT3s Satin finish,General UHPs, Eisenmann Race Exhaust, Sharked,CSL bumper, CSL diffuser,Depo smoked clears, Authentic ACS rear lip spoiler, Angel eyes.
Jump to top lorkar is offline   Reply With Quote
Old Fri, Jan-08-2010, 05:07:41 AM   #14
RedM3/4
Clogged versus spraying efficiently is two ends of the spectrum. I am trainalbe. Show me engineering drawings of how this supposed self-cleaning works (I'm an engineer, I can understand the drawings) and if it looks foolproof, I'll concede my error, which I've done in other threads when it occurs. I've got a few years on you working on autos, and have worked in the machine tool industry on all sorts of servos, motor controls, hydraulic units, on and on. Again, I'm trainable, not looking to have a major arguement.
As stated, I've seen remarkable real world results using techron in a couple of cases.
Buying perfect gasoline and doing perfect fuel filter changes is probably the most effective, but we live in an imperfect world, not that techron or any additive will reverse long-term neglect. But the cost to do this every 10k miles or so is a rounding error.
ADS
Old Fri, Jan-08-2010, 05:43:14 AM   #15
Donovan
subscribed
Old Fri, Jan-08-2010, 04:07:11 PM   #16
pmskreta
Reputation: 0 pmskreta is on a distinguished road
I used the Redline SI-1 at 45K. Drove to Huntington Beach, CA. from Las Vegas. I did it as maintenance as I didn't have any problems with the car. I got slightly better fuel economy on the trip. i plan on putting in a bottle at every oil change going forward. I only use Chevron Super Unleaded.
2004 M3: Redline 10W40, P/S Fluid, D4 ATF, 75W140, Water Wetter, SI-1
1974 2002: Redline 10W40, MTL 70W80, 75W90 + friction modifier, Water Wetter, SI-1
Jump to top pmskreta is offline   Reply With Quote
Old Fri, Jan-08-2010, 04:09:00 PM   #17
nwthunder
nwthunder's Avatar
Reputation: 0 nwthunder is on a distinguished road
I did at my service II
TT 04.5 Cummins
03.5 E46 M
Jump to top nwthunder is offline   Reply With Quote
Old Wed, Jan-20-2010, 10:20:47 PM   #18
Kaveh
Kaveh's Avatar
Reputation: 0 Kaveh has disabled reputation
Iran
From what I see and logically nothing can be less harmless than ultrasonically cleaning the fuel injectors. Assuming that the injectors after are the same as before and are not replaced with new ones. Look at the difference before and after.
http://www.youtube.com/watch?v=y_zWDvCjbu0
'01 TiAg/Grey M3 Vert ::: 6MT ::: LEDs ::: CWP ::: 19" CSL (current)
'01 LSB/Grey M3 Coupe ::: 6MT ::: CWP ::: 19" (Sold)
'01 Imola/Black Vert ::: 6MT ::: CWP ::: 19" (Sold)
'04 TiAg/Black M3 ::: SMG ::: NAV ::: Cold weather Package ::: PDC (Sold)
Jump to top Kaveh is offline   Reply With Quote
Old Thu, Jan-21-2010, 12:48:53 AM   #19
jph28
Chin 3/3 @ VIR Full
Reputation: 0 jph28 is on a distinguished road
I had a failed injector last week at 48k miles. I hadn't read of these failures before - uncommon for the E46 M3?
2004 SilverGrey 6MT
2012 VW JSW TDI 6MT
Past - '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is offline   Reply With Quote
Old Thu, Jan-21-2010, 12:59:13 AM   #20
kaiv
SoCal vanos/valve specialist :D
France
I've used BMW's fuel system cleaner once. The bottle looks just like the techron or whatever it is. I wouldn't be surprised if it's the same product with a different label. I didn't feel a difference though, car runs good anyway but I guess it cannot hurt at my mileage (100k+).
AW S65 E92 6MT
past: AW S65 E90 6MT- LSB S54 E46 6MT- JB S52 E36 5MT
Kaiv's SoCal Feedback! [M3Forum] [iTrader] [Bimmerforum]
cleaners, fuel, injector, regularly
Discussing Do you regularly use fuel injector cleaners on your M3? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
