Old Fri, Jan-22-2010, 04:40:48 AM   #31
ILLuSioNz X
Currently doing some math
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
i used one of these in my old ford that had been sitting for a while, about ten min later, i couldn't get it to stop backfiring after i let off the gas...maybe it wa the old gas, but i just don't believe new cars need injectors cleaned.
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Sat, Jan-23-2010, 03:36:43 AM   #32
Cimbom
Reputation: 0 Cimbom is on a distinguished road
If you are using 91 or above as you are supposed to, you do not need it. I do it every six months considering gas is not perfect.
05 m3 6 spd w/CSL 19" wheels, CP and SCP, gray ext, black int and AM black trim.
Jump to top Cimbom is offline   Reply With Quote
Old Sat, Jan-23-2010, 03:39:43 AM   #33
genuity
Reputation: 0 genuity is on a distinguished road
Originally Posted by Kaveh View Post
From what I see and logically nothing can be less harmless than ultrasonically cleaning the fuel injectors. Assuming that the injectors after are the same as before and are not replaced with new ones. Look at the difference before and after.
http://www.youtube.com/watch?v=y_zWDvCjbu0
Thanks for the video--I think I am convinced
Does anyone know what that tech is spraying on the o-rings/tips of the injectors before he installs them around 5:04? I could not get quite a good look but I do see the Wurth logo.
Edit: After watching it a few times, I saw enough to figure it out: Wurth HHS 2000. The HHS 2000 has been discontinued and replaced with a more EPA compliant formula HHS-K.
Jump to top genuity is offline   Reply With Quote
cleaners, fuel, injector, regularly
Discussing Do you regularly use fuel injector cleaners on your M3? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
