Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Fri, Jan-08-2010, 05:00:44 PM   #1
sharksM3evo
Reputation: 0 sharksM3evo is on a distinguished road
Default very rough idling
ive a 98 M3 evo with 120k on it, the car seems its about to cut out but when i put a bit of rev on it its perfect, its so bad the car shakes on the suspension. i found a cracked pipe on the idle control valve and replaced the pipe and cleaned out the idle control valve hoping that would fix it but no joy at all still the same, anybody got any ideas what i can check next ?
Jump to top sharksM3evo is offline   Reply With Quote
Old Fri, Feb-05-2010, 04:08:30 AM   #2
JasonM3/4
Reputation: 0 JasonM3/4 is on a distinguished road
hey sharks, did you ever figure out the rough idle? ... my car has been idling rough for a while now and i can't figure out why. cleaning the ICV is definitely a good place to start and i may have to do that again. ... other causes might include the following:
-worn engine mounts
-air hose leak
-clogged/dirty air filter or air intake valves
-camshaft problem(?)
Jump to top JasonM3/4 is offline   Reply With Quote
idling, rough
Discussing very rough idling in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
