Old Mon, Feb-22-2010, 05:02:36 AM   #1
2GRLS1M3
AMG LOL
2GRLS1M3's Avatar
Reputation: 0 2GRLS1M3 is on a distinguished road
Default how to calculate wheel spacers
i have csl rims and im dropped on billstiens pss9 with 2 degrees of camber in the rear and 1.5 in the front and stretched tires 215/35/19 in the front and 245/35/19 in the rear and my rims especially the front are way too far in so i want to get spacers but dont know the best way to calculate the spacer size i need to make the rim poke just a little bit does any one have any advice or a calculator of some sort for this? or maybe even someone running a similar set up could tell me what they are using
04 Carbon Black 6SPD ///M3
Vorsteiner CF Hood, Vis CSL CF Trunk, CF Splitters, Bilstien PSS9, CSL Rims, 8K Fog Lights, 30 LED Angel Eyes, Corner Light Delete, DRL Delete, Psycho Mod, SPC Control Arms, Frenetik Cross-Drilled & Slotted Rotors, Hawk Brake Pads, UUC SSK, V1 Hardwire, ZHP Knob, Alcantara Shift Boot, Color Matched Kidney Grills, Matte Black Fender Grills, Agency Exhaust, 20% Tint
Jump to top 2GRLS1M3 is offline   Reply With Quote
Old Mon, Feb-22-2010, 05:12:41 AM   #2
Cata893
Cata893's Avatar
Reputation: 0 Cata893 is on a distinguished road
HERE you go try this link! http://thenobot.org/apps/wheel_size....wheel_spacer=0
Current Cars: 97 F150, 00 VR6, 03 Stang, 04 M3, 04 YFZ450
Jump to top Cata893 is offline   Reply With Quote
Old Mon, Feb-22-2010, 05:25:46 AM   #3
2GRLS1M3
AMG LOL
2GRLS1M3's Avatar
that's perfect thank you
Old Fri, Mar-05-2010, 03:13:02 PM   #4
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
The best way to understand which size spacer you need, is to simply measure from the top outside edge of your tire to the inner lip of you fender. This will give you the best idea on how much size you have to work with, and to decide on how much your wheels need spaced.
Once you know that let we will be able to recommend which size will be the best fit for your application.
Here is a diagram that might also be of some help...
Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
sales@ecstuning.com | customerservice@ecstuning.com
Customer Service Hours: 8:00 AM to 8:00 PM EST
Sales Team Hours: 8:00 to 11:00 PM EST
800.924.5172
Facebook | YouTube|OEM BMW Part Number Search
Jump to top ECSTuning is online now   Reply With Quote
Old Fri, Mar-05-2010, 03:42:31 PM   #5
SIN3
Wheel Fitment Connoisseur
SIN3's Avatar
Reputation: 0 SIN3 is on a distinguished road
if you want legit fitment, buy 3 different sizes. 5, 10 and 15mm trial and error. 9 times out of 10 you'll put on one size because you are not "sure" then end up buying another set to push them out farther. i started with 12/10 on my OEM 19s now i am at 20/15
2006 M3 Cabrio sold
"keep it clean, keep it OEM+"
Jump to top SIN3 is offline   Reply With Quote
Old Thu, Mar-11-2010, 03:42:10 AM   #6
capnmark4
We're not going to Guam are we?
capnmark4's Avatar
Reputation: 0 capnmark4 is on a distinguished road
Antarctica
OK, I'm a bit confused. I measured my gaps over the weekend using a metal bar laid across the face of the tire (Potenzas on OEM 19s). Measuring the front, I got 1/2" so 12-15mm should be right. However, in the back, the bar hit the middle of the fender lip (bar is 1/8" thick) so I'm thinking I shouldn't even do spacers. Not sure how anyone could get by with 10mm spacers in the back based on what I am seeing without some camber dialed in.
Mark
'06 M3 Cabriolet/SilberGrau/Gray/SMG
clear reflectors, smoked corners, DICE Silverline Pro
New pic coming soon
BMWCCA 429926
Jump to top capnmark4 is offline   Reply With Quote
calculate, spacers, wheel
Discussing how to calculate wheel spacers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
