BrOke
![]() Location: Chicagoland
I searched Google and here and a bunch of other forums but couldn't find any definitive answers.
I know the passenger dash trim just pops out, so that will be easy. My question is, how do you remove the door handles if it is even possible? ![]() Also, what about removing the shifter trim? I plan on going with a brushed aluminum look like that off of a sport package E46 car. Does anyone have any pictures of all the wood painted brushed aluminum? I already have a RK2 brushed aluminum knob from UUC and plan on getting their matching e-brake handle as well. Thanks!
#2 | ||
User
![]() Location: CO/IL
Pull the door panel off. Unscrew the door handle
--Brent '97 Arctic coupe 171k '04 Flash Green S60-R GT 77k Quote:
Like a carpenter that makes stairs
![]() Location: NoVA
^ it's not really quite that easy. The door handle is glued between the door panel insert and the door card thus once you remove the screws you still have to jiggle it out... subsequently making the insert "loose". You could reglue the insert to again I suppose, but I was always hesitant to try that.
Best advice is to check out member mike27's mod his GF/Wifey did awhile back and he just did a nice job of recovering them with black material. Search for his old thread. GL.
#4 | ||
User
Really? Shoot, I couldn't tell there was any glue there. I'm just going to buy new door panels when I get rid of the wood.
#5 |
^ that's what I ended up doing... but that's an expensive route
#6 |
Looks like mike removed it anyway...
http://www.m3forum.net/m3forum/showthread.php?t=116776 But the issue I saw when I looked at this was the metal tabs that have the screws go through them are glue in between the panel - thus my original comment. Maybe there is a clever way to get around this...
#7 |
BrOke
Thanks guys!
Now, any pictures of someone running brushed aluminum?
#8 |
Check the Rhyme
![]() Location: Los Angeles
How exactly are you planning on painting the wood "brushed aluminum". Brushed is a finish and not a color, so I would recommend not going through the hassle of trying to paint on a texture, but look around and see if someone sells a brushed aluminum center console. I've never seen one, but then again there are lots of things I haven't seen.
![]() SAnta MOnica, ca N8IVE. 1999 M3 Cosmos 5 spd koni's and RSM's....the rest is stock |
#9 |
Relentlessly Awesome
![]() Location: Seatbelt not required
if you get all your wood off intact PM me i might want to buy.
#10 |
Hello
![]() Location: Florida
Firewood shortage in NH?
| conversion, e36, luxury, trim, wood |
