Old Tue, Mar-09-2010, 12:51:38 AM   #1
toddkageals
Reputation: 0 toddkageals is on a distinguished road
Default Weird Electrical Issue
Guys,
I have a weird problem with my 2002 M3 Vert. This happens every few weeks or so. Today I was driving along and the CD player started cutting out every few seconds, then the clock and miles on the trip odometer reset, the windows opened slightly to their "dropped" positions and would not come back up after the doors were closed, I got a red light on the close top switch, I think the Nav. display might have went off and then on again but I am not positive. After I stopped the car and reset everything by turning the key off and then on again, everthing was fine. The clock/date had to be reset but otherwise everything went back to normal. It's done this about 5-7 times in the last couple of months. Anybody know where I should start looking for this?
Thanks,
Todd
Jump to top toddkageals is offline   Reply With Quote
Old Tue, Mar-09-2010, 01:23:53 AM   #2
bleufiend
Reputation: 0 bleufiend is on a distinguished road
Possible bad alternator over or undercharging? Not sure if faults would store for it that could be read.
Jump to top bleufiend is offline   Reply With Quote
Old Tue, Mar-09-2010, 02:09:16 AM   #3
RedM3/4
have the battery terminals cleaned first, and check the battery voltage while there.
ADS
Old Tue, Mar-09-2010, 02:52:54 AM   #4
e46m3smg@16
Reputation: 0 e46m3smg@16 is on a distinguished road
hey man. i had the same problem. really confused me. it happened to me when i was on cruise control then everything cut out and the nav wet off then back on. i wasnt sure what it was and couldnt find much helpful info online. after like 6 times of doing that it just went away. hasnt happened since.
Jump to top e46m3smg@16 is offline   Reply With Quote
Old Tue, Mar-09-2010, 07:38:19 AM   #5
///M Rat
Brilliant in chaos
///M Rat's Avatar
Reputation: 0 ///M Rat has a spectacular aura about
Puerto Rico
Have your battery tested.
Jump to top ///M Rat is offline   Reply With Quote
Old Tue, Mar-09-2010, 07:29:47 PM   #6
Gregs///M
Gregs///M's Avatar
Reputation: 0 Gregs///M is on a distinguished road
Italy
And alternator.
2003 Alpine White BMW M3 Coupe
Modifications:Dice Ipod Interface [] Focal Utopia 6.5in components speakers(front), Focal Utopia 5.25in component speakers (rear) []JL Audio W3V3 Sub Woofer []
Eclipse Xa5000 5 ch amplifier [] Clifford 50.7 two way pager [] Custom interior trim (OEM Alcantara) [] Dinan Stage I tune. []
Jump to top Gregs///M is offline   Reply With Quote
Old Tue, Mar-09-2010, 10:25:01 PM   #7
smaglik
smaglik's Avatar
Reputation: 0 smaglik is on a distinguished road
check your ground points.
2002 BMW M5
2007 Nissan Xterra
2009 Honda Fit
Jump to top smaglik is online now   Reply With Quote
Old Wed, Mar-10-2010, 12:54:35 AM   #8
toddkageals
Guys,
Thanks for the replies. I don't think the battery is an issue. The headlights don't even dim when I start the car and even through this very cold winter I have had "0" problems cranking/starting the car. The car has 70K and the alternator was replaced by BMW before I got it. I guess there is no way to rule out the alternator but I don't see any evidence that it's not charging. Obviously the problem is intermittent so I guess I can't rule out some short in the alternator. Where are the ground points on an E46 M3 vert. ? I THINK that any failed device on the Ibus can cause this sort of problem but I am not sure. The car was not doing this when I bought it and I have only done two thing that I can think were electrical in nature. I installed the hardtop installation kit but that's just plugging it in. I also replaced the nav. unit with a MKIV that I bought used. So....I was hoping to find someone who had similar issues who might be able point me in the right direction. Prior to the most recent occurence the problem had not occured for about a month or so. I almost wish it would just quit working so I could find the source of the issue!
Old Wed, Mar-10-2010, 02:42:03 AM   #9
smaglik
smaglik's Avatar
well, on the older ones, there is one near the battery, one near the back of the block, and one under the dash. in fact, the first thing you do when you take ownership of an e24 is to clean the grounds...hehe
i have not had to troubleshoot that on the e46 yet, so i do not have personal experience. there was a thread awhile back where a member had similar odd issues, and reconnected something under his seat, and it fixed the issue.
check your bentley, it should be in there.
2002 BMW M5
2007 Nissan Xterra
2009 Honda Fit
Old Wed, Mar-10-2010, 04:22:55 AM   #10
kid_m3
kid_m3's Avatar
Reputation: 0 kid_m3 is on a distinguished road
My coupe did the same thing. It ended up being a wire underneath the drivers seat.
Jump to top kid_m3 is offline   Reply With Quote
electrical, issue, weird
Discussing Weird Electrical Issue in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
