![]() Location: NoVA
Do you need to do anything special to bleed brakes?
Any requirments for ABS or proportioning valves or just bleed like normal? Anyone verify this in the Bently manual?
![]() '06 CB/IR w/SMG/NAV/HK/Eibach/19" BBS RGR/Hankooks |
zemperaye
![]() Location: San Diego
http://m3.madrussian.net/diy_brake_bleed.shtml
there really isnt anything special. Just remember to bleed the clutch as well. Are you flushing/replacing system? or just bleeding? ^^ should help. |
![]() Location: Los Angeles
According to my Bentley, if no air was/is introduced just behind the master cylinder than it's a pretty much a straight forward pressure bleeder procedure. But something interesting: Pressure bleeding at no more than 2 bar but should not be more than 20lbs. while someone is pumping the brake, interesting. Brake pedal should be held down before the bleeder is closed.
If air was introduces just after the master cylinder than you would need a DISplus/GT1 factory scan tool. The ASC and DSC systems use electronis controls and a sophisticated hydraulic unit. Once air enters the hydraulic unit, it is difficult to remove using traditional methods. |
#4 | |
![]() Location: Chitown
Also, Madrussian's bleeding procedure via a pressure bleeder is a waste of time IMO. Bleeding the system the conventional way (with a helper pumping the pedal) is faster and less of a hassle. |
#5 | |
Several have no problem, but it isn't exactly uncommon to damage the master cylinder on newer cars; the piston being pushed past where it normally would travel is described as being the potential cause. So maybe don't push as hard and far as you can go, or put another thickness of carpet or something behind the pedal for some insurance if you're not going to use a pressure or vacuum bleeder.
ADS Quote:
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1. Sold to my son, still in the family! 06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit. |
#6 | |
^^^ I bleed my brakes twice a year. That's 8 times in the last 4 years. And I never ran across anyone with M3 who damaged the master cylinder from bleeding the brakes using the old method, which IMO is still superior to the $40 pressure bleeder.
#7 | |
I bleed my brakes about three to four times a year, depending on track duties. If there is another body present, he will be designated to pumping (the brakes). If I'm by myself than the pressure bleeder comes out. |
#8 |
My 2 year flush is due this summer. The car has not (yet) seen the track and fluid in the MC looks good.
My plan was to install speed bleeders and flush manually. I was also debating installing SS lines, if I can do without draining to much fluid.
#9 |
#10 |
Yes, it's the same system. When I put my SS brake lines on, I thought the same thing. I didn't get air into the clutch, why should I bleed it? If you don't your brake pedal feels like there is air somewhere in the system. I didn't get a good brake pedal until I bled the clutch.
![]() 2003 e46 6spd M3 2008 e92 6spd 328xi 2006 Mitsubishi Evolution IX (sold) 1991 5spd Civic DX |
| bleed, brakes |
