| Off Topic Place to discuss this and that. (Threads/posts inside may contain material that is NSFW / offensive) |
![]() • Body: o Carbon/Kevlar widebody based on the Porsche 987 coupe. Every panel except the aluminum hood has been modified or replaced o Front bumper modeled on the 911 GT2 (997), rear bumper modeled on the 911 GT3 (997) o Custom carbon fiber rear diffuser and under-tray to reduce lift o 7” wider at rear wheels, 3” wider at front wheels. o 3000 lbs, 50/50 weight balance o 911 (997) Bi-Xenon headlights o 911 Turbo (997) LED front turn signals o 2009 911 (997) LED rear tail lights o Clear side markers programmed as turn signals • Engine/drivetrain: o Original 987 3.4l engine swapped for Porsche 911 3.8 X51 "Clubsport" motor o 911 X51 intake swapped for 911 Carerra S (997) 3.8l version with resonance chambers/flaps to improve bottom end and midrange power o TPC Turbo with advanced tuning option o 542 HP, 440 ft-lbs torque on less than 6psi boost with stock 11.8:1 compression, uses premium pump gas o 5.53 lbs/hp power to weight ratio o APR long tube headers, Jet Hot “Extreme Sterling” coated to help keep heat out of the enclosed mid-engine bay (Planned) Currently Miltek V2 Cayman Headers with Sport Cats. o Single mass lightweight flywheel and X51 clutch o Guard limited slip differential (Planned) Current Quaife Torque Biasing Diff. o Porsche short shift kit o 911 GT2 (997) front/corner complete radiator assemblies and ducts for engine cooling o 911 GT2 (997) center radiator and ducts, used for the turbo intercooler • Suspension o Bilstein PSS9 adjustable suspension, lowered 1 ½” o TPC Pro adjustable sway bars front and rear, with adjustable drop links o 911 GT3 (997) adjustable rear Toe links o MODE camber plates o 911 GT3 (997) Front uprights/bearing carriers o 911 GT3 (997) lower control arms, modified to reduce baseline negative camber • Wheels Tires: o HRE P43 lightweight forged aluminum “Monoblok” wheels, 20"x9" fronts, 20"x12" rears o Michelin PS2 tires. 255/30 ZR20 fronts, 325/25 ZR20 rears • Brakes: o 6 Piston 911 GT3 (997) front calipers with 355x32mm AP racing drilled 2 piece rotors o Rear: 4 Piston 911 GT3 (997) rear calipers with 322x32mm Porsche 993 Turbo drilled rotors, retains E-Brake functionality o GT3 front brake ducts o Pagid Yellow brake pads • Interior: o 911 GT2 (997) carbon fiber seats with integrated side airbags o Shroth 6 point harnesses o TC design harness bar o 911 Turbo (997) carbon fiber shifter knob o DB Carbon and Porsche interior carbon fiber trim pieces o Porsche European version leather sun visors, (no airbag warning stickers) o Pioneer Avic Z2, 7" touch screen stereo with Sat Nav/nav traffic, USB/Aux/IPOD inputs o Focal and Polk component speakers o Polk and Rockford Fosgate Amplifiers The Biggest Cayman Project Ever? Widebody, Turboed, X51 Cayman S. - Page 3 - Teamspeed.com And more pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by EKaru; Fri, Mar-19-2010 at 02:19:35 PM.. |
#4 |
Restricted
![]() Location: in your head stealing your thoughts
interesting.....it'd be interesting to see a regular cayman parked right next to it and a carrera s just to see how bastardized it is....
I've got diarrhea of the mouth....want to listen? |
#5 |
Mr. Goodlife
Cool story, bro.
Daily: 2003.5 E46 M3 Coupé: Not much stuff Track: 1995 E36 M3 Coupé: Lots of stuff ![]() |
#7 |
Mr. Goodlife
#8 |
Not bad, but you could buy a GT3 for the cost of this project, so why would you do this project instead?
answer: you wouldn't.
2004 Audi S4, 6 Sp. (Dolphin Gray/Black Silk Nappa) |
| cayman, porsche, project |
