Old Thu, Mar-25-2010, 11:05:44 AM   #1
PIR3lly
PIR3lly's Avatar
Reputation: 0 PIR3lly is on a distinguished road
Netherlands
Question Do I need to bleed the clutch on an SMG when doing a brake fluid change?
Hey guys, I've been searching the forum, but I can't really find an answer.
I have to do a brake fluid change soon and I've been reading the diy about this.
It says I have to bleed the clutch.
I'm just wondering if and how I do this on an SMG.
Is it nessecary? Do I need special tools? Can I do it myself or do I need to go to an bmw specialist?
Any restrictions on the type of brake fluid or should I just go with ATE 200 or RBF 600 (use it as my daily driver and almost never track the car)?
Jump to top PIR3lly is offline   Reply With Quote
Old Thu, Mar-25-2010, 01:00:42 PM   #2
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
Reputation: 0 tonggi is on a distinguished road
its the same as the caliper. its a bleeder nipple underneath the car by the tranny, driver side.
TiTS Racing in association with MMFN Racing and AYO STFU
Want to buy your High Mileage Car!
Jump to top tonggi is offline   Reply With Quote
Old Thu, Mar-25-2010, 01:40:30 PM   #3
ivietg04i
Reputation: 0 ivietg04i is on a distinguished road
does it just drains? thanks
Jump to top ivietg04i is offline   Reply With Quote
Old Thu, Mar-25-2010, 02:56:03 PM   #4
PIR3lly
PIR3lly's Avatar
Netherlands
Ok, so there's a nipple. But how do you bleed it?
I can't push in the paddle because there is no clutch paddle.
Old Thu, Mar-25-2010, 03:10:52 PM   #5
GotM?
Admiral Douchington
GotM?'s Avatar
Reputation: 0 GotM? is on a distinguished road
I don't have an SMG...but my guess would be a power bleeder.
- Chris
2004 Mystic Blue Metallic Convertible
Jump to top GotM? is offline   Reply With Quote
Old Thu, Mar-25-2010, 04:16:06 PM   #6
kingofqueenz
Reputation: 0 kingofqueenz is on a distinguished road
Italy
Its not required. I know of alot of smg owners who bled their brakes without doing the clutch fluid and it caused no problems.
Jump to top kingofqueenz is offline   Reply With Quote
Old Thu, Mar-25-2010, 04:43:43 PM   #7
.333 snubnose
.333 snubnose's Avatar
Reputation: 0 .333 snubnose is on a distinguished road
am i missing something?
why would you bleed the smg hydraulics when bleeding brakes?
For Rent: RTAB tool (MIS), FCAB tool (MIS), Valve Shim Kit & Tool
For Sale: OE FCAB brackets (lollipops)
Jump to top .333 snubnose is offline   Reply With Quote
Old Thu, Mar-25-2010, 05:41:33 PM   #8
PIR3lly
PIR3lly's Avatar
Netherlands
Not the smg hydraulics, but the clutch.
Clutch on a M3 uses the same fluid as the brakes (at least, that's what I've been told).
Just read this Diy and you'll see what I mean. Unfortunately he doesn't mention how it's done on a SMG.
So I could skip bleeding the clutch, but if I want to do it, I need to use a pressure bleeder, correct?
Old Thu, Mar-25-2010, 05:54:21 PM   #9
avusbluem3
avusbluem3's Avatar
Reputation: 0 avusbluem3 has disabled reputation
I was researching this a while ago but can't find the links now. I believe SMG does not use brake fluid to actuate the clutch, it uses the SMG fluid. It's independent of the brake system.
95 E36 M3 Avusblue/Dove Gray :Sold
02 E46 M3 Steel Grey/Black Nappa/SMG II
Jump to top avusbluem3 is offline   Reply With Quote
Old Thu, Mar-25-2010, 06:03:36 PM   #10
PIR3lly
PIR3lly's Avatar
Netherlands
If that's the case, then I shouldn't touch it. Could make things worse.
Hmmm...
Anyone know the right answer?
bleed, brake, change, clutch, fluid, smg
Discussing Do I need to bleed the clutch on an SMG when doing a brake fluid change? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
