Old Fri, May-18-2012, 01:23:04 AM   #21
Str8///Left
Leave the others behind.
Str8///Left's Avatar
Reputation: 0 Str8///Left is on a distinguished road
Default Re: Do I need to bleed the clutch on an SMG when doing a brake fluid change?
Originally Posted by Sandeep1212 View Post
Umm...........no.........it's about SMG...read the title.
So from what i gathered for 6mt makes sense to bleed the clutch also because you want all the fluid that will be in the same reservoir to be changed......and for SMG just do the brakes because there is a different reservoir and fluid for the SMG clutch making it not neccessary to get all the brake fluid out.....Correct?
Yes. It's recommended to flush out brake fluid every two years.
Jump to top Str8///Left is offline   Reply With Quote
bleed, brake, change, clutch, fluid, smg
Discussing Do I need to bleed the clutch on an SMG when doing a brake fluid change? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
