Old Thu, Dec-02-2010, 11:33:47 AM   #31
magic911
Reputation: 0 magic911 is on a distinguished road
Originally Posted by duvinclunk View Post
Considering these. I just wish I could turn them off if I was bored of them.
you can just wire them to the fog lights. much better option for me.
Jump to top magic911 is offline   Reply With Quote
Old Thu, Dec-02-2010, 04:12:32 PM   #32
mjgum3
Reputation: 0 mjgum3 is on a distinguished road
just wire inside your cabin to a switch
Jump to top mjgum3 is offline   Reply With Quote
Old Fri, Dec-03-2010, 03:56:28 AM   #33
CSML23
Reputation: 0 CSML23 is on a distinguished road
Does anyone know which wiretaps came with the lights and where I can get them? I broke the 2 that were supplied as I was trying to close them with pliers
Jump to top CSML23 is offline   Reply With Quote
Old Fri, Dec-03-2010, 04:02:07 AM   #34
Agey
Agey's Avatar
Reputation: 0 Agey is on a distinguished road
How do you wire them to the fogs? I would want to do it that way
6MT ///M | too stock for anyone's eyes
Jump to top Agey is online now   Reply With Quote
Old Fri, Dec-03-2010, 04:03:30 AM   #35
duvinclunk
nightman.
duvinclunk's Avatar
Reputation: 0 duvinclunk is on a distinguished road
But I also want to run them without fogs. I'm picky.
06 M3 ZCP. IB/Black. Not Stock.
02 M3. TiAg/Imola. TCKline. Dinan. Forgestar. (sold )
Jump to top duvinclunk is offline   Reply With Quote
Old Fri, Dec-03-2010, 05:44:58 AM   #36
SamkM3
Reputation: 0 SamkM3 is on a distinguished road
Run the power wire to a switch instead of tapping into the accessory wire and terminate the other side of the switch to the fuse box. I put mine in the ashtray
Jump to top SamkM3 is offline   Reply With Quote
Old Fri, Dec-03-2010, 05:56:44 AM   #37
SamkM3
They sell something similar to it at Autozone think there called trailer splices, thats what i call them anyway if not just use a inline (barrel) splice or solder.
Old Fri, Dec-03-2010, 06:40:25 PM   #38
Agey
Agey's Avatar
So I want to have my angel eyes turn on when I press the fog light button, do I just wire the angel eye cables to the fog lights themselves? Can someone help me out here.
Old Fri, Dec-03-2010, 09:57:14 PM   #39
CSML23
Anyone have trouble reinstalling the inner headlight trim after installing the angel eyes? I can seem to place it back in without having it push up against the rings. Even if I push them back all the way they still rub. I tried leaving the trim loose but I cant put the clear headlight cover on properly if I do. I'm not sure if I should just leave the headlight trim out.
Old Fri, Dec-03-2010, 10:59:03 PM   #40
SamkM3
Yes you can wire it into the fog light power wire itself not sure where that harness runs instead of using the accessory wire to tap in off of. I would splice it into the right side fog light just follow the harness or splice it in near the fog light itself.
angel, eyes, led, orion™, predator, remote
Discussing Predator Orion™ V2 LED Angel Eyes with Remote On in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
