Old Tue, Apr-06-2010, 01:32:45 PM   #1
stroup
noob
Reputation: 0 stroup is on a distinguished road
Question Coolant Temperature Gauge Sender Screwed Up
Just got the car (1995 M3) running after a head gasket change and all seems well except my temp gauge.
IT
-is stuck high in the overheated position
-with ignition turned the needle goes up to red and light turns on
-with engine running the needle goes up to the same position but the light does not turn on
MIND YOU THIS IS WHEN THE MOTOR IS COLD, I'm not that big a noob lol.
so according to Bentley
"If the gauge needle reads too high when the engine is cold, remove the harness connector from the sender. Turn the ignition on. If the gauge needle position does not change, the wiring or the gauge is shorted to ground If the gauge needle drops, the sender is faulty and should be replaced."
This is my problem, after this test the needle position does not change (meaning goes back to same high position, basically the wiring or the gauge is shorted to ground). Bentley did a fine job of diagnosing this problem but fails to explain how to FIX IT WTF.
My one possibility that I can think of is that maybe i got the two grounds on the head cover (near ignition coils coming from mounting bolts) placed incorrectly. Does anyone know the proper placement of these grounds? Or how to fix the gauge would be sweet as well.
Thanks!
Jump to top stroup is offline   Reply With Quote
Old Tue, Apr-06-2010, 05:55:26 PM   #2
Volcom8190
Volcom8190's Avatar
Reputation: 0 Volcom8190 is on a distinguished road
You switched the wires between the 2 senders, swap them around
Jump to top Volcom8190 is offline   Reply With Quote
Old Wed, Apr-07-2010, 02:50:21 AM   #3
stroup
noob
tried it, got the same result
coolant, gauge, screwed, sender, temperature
Discussing Coolant Temperature Gauge Sender Screwed Up in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
