Old Fri, May-14-2004, 10:50:31 PM   #1
aemixes
Reputation: 0 aemixes is on a distinguished road
Default How to remove and install front reflectors
Can anyone explain to me how I'm supposed to take off the front reflectors and put on the new ones? Thanks
Jump to top aemixes is offline   Reply With Quote
Old Fri, May-14-2004, 10:52:01 PM   #2
boomer
Wanna play poker?
boomer's Avatar
Reputation: 0 boomer is on a distinguished road
You need a flathead screwdriver and a thin towel. Basically, all you need to do is squeeze the screwdriver underneath the reflector, apply some pressure, and it should gently pop out. Wrap the screwdriver in the towel so that you don't scratch your paint.
-Paul
2004 M3 Coupe Jet Black / Black
Now Playing: SMG : NAV : Xenon : HK : Premium : 19" rims : AL trim : Lumbar : 35% tint : SilverVision : Painted reflectors : V1 hardwired w/remote display : DDEs : Xenon interior lights : SPP Fogs : Colored roundels : Alarm : Sirius : Bluetooth
Coming Soon: Hamann brake ducts : CSL trunk : CF lip : PSS9
Jump to top boomer is offline   Reply With Quote
Old Fri, May-14-2004, 10:53:56 PM   #3
ZQQM3R
SUBLIM3
Reputation: 0 ZQQM3R is on a distinguished road
You can do it with your fingers, make sure your nails are short. Place finger tips on top edge of reflector, apply downward force then pull towards u.
Jump to top ZQQM3R is offline   Reply With Quote
Old Fri, May-14-2004, 10:54:10 PM   #4
Kevin034
Kevin034's Avatar
Reputation: 0 Kevin034 has disabled reputation
Also, watch the towel. You'll be amazed how many people actually punctures the tower w/ the screw driver and go straight into the paint and not know it.
Instead of a metal screw driver, try a plastic instrument that's flat and durable.
Jump to top Kevin034 is offline   Reply With Quote
Old Fri, May-14-2004, 11:26:20 PM   #5
aemixes
Awsome thanks
Old Sat, May-15-2004, 01:17:59 AM   #6
MattMan
Modded
MattMan's Avatar
Reputation: 573 MattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond repute
http://m3.madrussian.net/diy_painted_reflectors.shtml
MattMan
2013 IB E92 M3 6MT
IG: @mattzcp
Jump to top MattMan is offline   Reply With Quote
Old Sat, May-15-2004, 01:19:48 AM   #7
Kevin034
Kevin034's Avatar
If you are going to follow madrussian, careful of the screw and the towel. Just look at what I wrote above ^^^^
Old Sat, May-15-2004, 02:52:37 AM   #8
umnitza
Guest
umnitza's Avatar
Reputation: 0 umnitza is on a distinguished road
first figure out what type you have, don't just go poking in there.
It's either a clamp or a screw, the screw is *duh* easier
Jump to top umnitza is offline   Reply With Quote
Old Tue, Dec-25-2012, 08:38:49 PM   #9
kihun
Reputation: 0 kihun is on a distinguished road
Default Re: How to remove and install front reflectors
holy crap this reflector material is so weak.
E46 M3 - Sold
E92 335i - Current
Jump to top kihun is offline   Reply With Quote
Old Tue, Dec-25-2012, 09:02:02 PM   #10
lmtfi
lmtfi's Avatar
Use a credit card.
How to remove/install Front/Side Grilles kewlwhip E46 M3 (2001-2006) 8 Tue, Mar-05-2013 07:24:14 PM
Do i have to remove bumper to install ACS front lip and Rear Diffuser? M3 PWR E46 M3 (2001-2006) 1 Sun, Feb-05-2006 10:09:20 AM
Any L.A. shops that could install clear reflectors? EM3 E46 M3 (2001-2006) 10 Tue, Sep-13-2005 08:56:29 AM
anyone install/remove fogs? toddcfii E46 M3 (2001-2006) 3 Sun, Apr-03-2005 03:24:28 AM
Remove the front bumper if I have a lift ( lip install ) nojobxl Faults, Fixes and DIY 2 Mon, Nov-01-2004 11:45:28 PM
Discussing How to remove and install front reflectors in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
