Old Fri, Apr-23-2010, 02:32:03 PM   #1
OJM
Reputation: 0 OJM is on a distinguished road
Default Need advice: 60k, broken rear spring-what else should I replace?
Need some advice re suspension. I purchased my 2003 M3 Vert SMG six months ago with 57K on it. The car was reasonably well maintained with all oil changes and Inspection I and II completed. I don't have much additional info regarding other work done on the car, I believe everything is stock. I just passed 60k on the odometer.
While installing my summer setup, I notice that a small portion at the bottom of my passenger side rear coil spring had cracked and broken off. I am located in NJ and the roads here are a nightmare so this is no shocker. I am planning to replace the rear springs (or should must I do all 4), but figured I would ask the collective M3 community what else they would suggest I replace suspension-wise given the mileage on the car. Given my driving style and use of the M (daily driver and occasional weekend getaways - no track), I am more interested in ride comfort than A++ handling. I plan to do the labor myself and really would like to keep the total parts expense around $1,000 given financial constraints.
Given my mileage, any suggestions regarding (1) what to replace other than springs (2) brand of springs to get the best ride comfort w/o serious impact to handling? Also, any other suggestions on routine maintenance at 60k given my mileage?
All advice appreciated!
Jump to top OJM is offline   Reply With Quote
Old Fri, Apr-23-2010, 02:43:53 PM   #2
deilenberger
deilenberger's Avatar
The broken BMW rear springs is really going around. My local friendly mechanic friend had 4 BMWs in a week show up for the same thing. It seems no one gets past 60k miles in NJ with a convertible M3 without needing springs. The bottom coil snaps off - and if you look you can see where it was caused by rust starting on the outside, and weakening the spring.
If you're looking for a comfortable ride - 18" tires are more comfortable then 19" (and 17's like my winter set are even better.) Many people report putting Koni shocks on and adjusting the damping down will improve the ride quality. Just putting softer springs on won't - it will lower the car and likely make ride quality worse since the stock shocks will now be bottoming out. I'd go for stock springs and Koni shocks if I was looking for ride quality.
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Old Fri, Apr-23-2010, 04:33:04 PM   #3
Bents
Reputation: 0 Bents will become famous soon enough
England
Agree with Don - lots of these springs are breaking. Second one I've heard of in just a few weeks.
Jump to top Bents is offline   Reply With Quote
Old Fri, Apr-23-2010, 04:46:35 PM   #4
zemperaye
zemperaye
zemperaye's Avatar
Reputation: 0 zemperaye is on a distinguished road
I would definitely go with Koni shocks. Stick with OEM springs if you are not looking to do any drop. I would take a look at your RTABs as well, if your springs cracked and broke off, I would be almost sure your RTABs have failed as well. if not, might as well check.
Jump to top zemperaye is offline   Reply With Quote
Old Fri, Apr-23-2010, 09:19:03 PM   #5
OJM
Okay, thanks for the recommendations!
The consensus is:
Springs - go with OEM (willing to consider other upgrades for brands, but don't want to lower due to deep slope entering driveway!)
Shocks - go with KONI
Check RTABs. What do folks recommend for a replacement? OEM? Again, nit tracking, just looking for good handling/comfort on the street and highway.
I am sticking with 19inch wheels/tires as they are in good shape and I like the look.
Where do folks recommend I purchase the parts above? I have order from Turner in the past and purchased from my local stealer (JMK in NJ). Also, regarding installation, I was planning to do myself, but will consider having installed if the labor is reasonable as my weekend schedule is always tight and I am unsure how many hours it will take to do the front and back (springs, shocks and RTABs). Thoughts?
Old Fri, Apr-23-2010, 09:55:10 PM   #6
Panzer25
Reputation: 0 Panzer25 is on a distinguished road
Exact samething just happened to me w/ 46k miles. I am also going Konis with new-to-me rear springs.
Jump to top Panzer25 is offline   Reply With Quote
Old Sat, Apr-24-2010, 06:55:34 AM   #7
zemperaye
zemperaye
zemperaye's Avatar
Get the new OEM RTABs + shims. Actually, not sure if you would need the shims with the new OEM RTABs. you might have to double check as I am running powerflex. Just get the parts from tischer. www.getbmwparts.com
RTAB labor is quite costly IMHO (i dont know your financial standards as to what you consider costly, but I am a cheap bastard when it comes to something that can easily be done) RTAB plus suspension install will run over $1000 at the dealership. Going to an indy will run you less. Good luck
The consensus is:
Old Thu, Sep-09-2010, 08:38:52 PM   #8
rhumbline
rhumbline's Avatar
Reputation: 0 rhumbline is on a distinguished road
Geez, turned my back for a second and yet another thing breaks, this time a rear spring! How in Hades do you make rear springs so cheaply that they actually break in average usage at a mere 50K miles? The M3 is a glorious car to drive, when not in the shop, but the abominable QC and materials durability would embarrass a Yugo.
With all that off my back, until the next weekly part F-up, what about shocks (yes, they said one is starting to seep a bit, not to mention the shock mounts looking tired, and...)? Konis seem to get high marks, but how do they compare to Bilstein HDs?
PS Reported this to NHTSA's Recall and Safety reporting page to keep BMW's feet to the fire, http://www-odi.nhtsa.dot.gov/ivoq/index.cfm. There's simply no excuse for springs to actually break at 50K miles on a conservatively driven car.
Jump to top rhumbline is offline   Reply With Quote
Old Thu, Sep-09-2010, 10:46:23 PM   #9
teoirimia
teoirimia's Avatar
Reputation: 0 teoirimia is on a distinguished road
Then you go to the dealer and finds more things wrong with the car. And then you pick it up after they fixed it and payed deep money for it and something is still wrong with the car that wasn't there before you took it to the dealer. LAMO Love the car hate the game we got to play to maintain it and keeping the car in good condition.
2002 E46 M3. Voisteiner CF Hood, Trunk, Rear Diffuser and Front Splitters. TSW weels, Nitto tires. Headers (no cats), Agency Power Exhaust, Evo Sport Underdrive Pulleys (Audiophile), Angel Eyes.
Jump to top teoirimia is offline   Reply With Quote
Old Fri, Sep-10-2010, 01:13:23 PM   #10
christopherp
Reputation: 0 christopherp is on a distinguished road
Why don't you like the powerflex rtabs? OEM the best replacement for rtabs?
2005 AW/Cinn 6sp, Vert, oem ZCPs
2001 Mustang Cobra (sold)
Jump to top christopherp is offline   Reply With Quote
60k, advice, broken, rear, replace, springwhat
Discussing Need advice: 60k, broken rear spring-what else should I replace? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
