Old Sun, May-09-2010, 09:10:03 PM   #1
Philly_swedem
Philly_swedem's Avatar
Reputation: 0 Philly_swedem is on a distinguished road
Sweden
Default TPS error code P0121 - G69, which sensor?
Hi.
I got this code: TPS error code P0121 - G69 - excessive signal.
Which one of the 3 TPS is it?
Thanks!
Filip
Jump to top Philly_swedem is offline   Reply With Quote
Old Sun, May-09-2010, 09:16:35 PM   #2
///M3-QTR
ॡحمدॡ
///M3-QTR's Avatar
Reputation: 0 ///M3-QTR is on a distinguished road
Qatar
http://www.m3forum.net/m3forum/showt...ght=TPS+sensor
Euro 01 IR/IR ///M3 113K miles|281rwhp on DD
^ SOLD^
Engine: aFe drop in filter, SS race exhaust |Drivetrain: AS Ultimate SSK w/ UUC DSSR, ZHP shifter knob, GSP clutch pedal.
Suspension : AST 5100's 600/750 w/ Vorshlag camber plates, PF RTAB's, RE RSM, UUC adjustable rear camber arms, TMS reinforcement kit & endlinks |Braking: Cool Carbon, StopTech SS lines| Exterior: Alufelgen SF-71's, VORS(1x1) CSL bumper, trunk and diffuser,OEM rear LED's, blackout front grills, CF side grills , smoked corners and side signal lights, TFX conversion, Umnitza 4300K V2's angle eyes, Euro wide convex mirrors| Interior: US spec trunk release button, OEM alcantara boot, OEM alum pedals.
Jump to top ///M3-QTR is offline   Reply With Quote
Old Sun, May-09-2010, 09:22:06 PM   #3
Philly_swedem
Sweden
Edit: Still haven't found which sensor "0121" is
Old Mon, May-10-2010, 12:50:00 AM   #4
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
You'll have to test them. It's usually the one above the oil filter the one that fails
E90 Jerez M3
335i Vert
Jump to top mredwin25 is offline   Reply With Quote
Old Mon, May-10-2010, 04:24:24 AM   #5
playskool1
NorCal's Valve Adjustment guy
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
your gas pedal potentiometer
01[LSB][Cinnamon][6 Spd.]ESS VT475|3000lbs.|6.31lbs./hp
PM me for valve adjustment and inspection 1&2 deals!
Jump to top playskool1 is offline   Reply With Quote
Old Mon, May-10-2010, 07:04:57 AM   #6
Philly_swedem
Sweden
100% sure?
I heard that the code P0121 is the one next to the oil filter, also knows an "A", then "B" is the one under the intake and "C" is the gas pedal. "B+C" should have their own codes, I believe one of them is P0226.
Old Mon, May-10-2010, 12:09:22 PM   #7
mredwin25
mredwin25's Avatar
Again test them and see which one it is. I'm on my second TPS and it's always been the one next to the oil filter.
E90 Jerez M3
335i Vert
Old Mon, May-10-2010, 12:11:38 PM   #8
Philly_swedem
Sweden
Did you get the same code; P0121?
Old Mon, May-10-2010, 01:46:50 PM   #9
AUTOB0T
AUTOB0T's Avatar
Reputation: 0 AUTOB0T is on a distinguished road
I had the same issue, mine was the one above the oil filter, and i got the same code as you.
Maverik
"keep your eye on the horizon"
Jump to top AUTOB0T is offline   Reply With Quote
Old Mon, May-10-2010, 02:30:09 PM   #10
Philly_swedem
Sweden
Thanks Autobot!
Do you know if the code P0121 is the specific code for THAT sensor or if it just is a general code for any of the 3 sensors?
code, error, g69, p0121, sensor, tps, tps po121 error throttle
Discussing TPS error code P0121 - G69, which sensor? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
