Old Fri, May-14-2010, 01:44:12 AM   #11
xfeastonarsex
xfeastonarsex's Avatar
Reputation: 0 xfeastonarsex is on a distinguished road
Originally Posted by bimmer777 View Post
Can't believe you left the gas tank on there while welding. Not the safest but glad it worked out fine. I would NOT recommend this to anyone who will potentially be doing this though.
No, we took the gas tank off for sure, I would not recommend to leave it on either. It is behind the welding blanket on the ground. He said the only thing that would make him nervous was if we left it up, I said it would make me nervous also.
2005 Jet Black M3 6-speed
1989 Mazda Rx-7 GXL
1995 Toyota Corolla 300,000 mile high club
Jump to top xfeastonarsex is offline   Reply With Quote
Old Fri, May-14-2010, 02:24:07 PM   #12
razzamagoo
Reputation: 0 razzamagoo is on a distinguished road
How hard was it to take the gas tank off and put it back on? My old DSM was a PAIN to do.
The rear diff stuff doesn't look hard at all....just heavy from what I'm seeing.
Jump to top razzamagoo is offline   Reply With Quote
Old Sat, May-15-2010, 08:01:02 AM   #13
xfeastonarsex
I just laid underneath the gas tank and used my knees to prop it up, 3 bolts and it came right off (not including the 2 connectors to the front of the car, the filler tube and the sender unit and fuel pump cable, hehe). I would just use as much gas in the tank as possible to make it lighter, the interesting design of the tank makes it ergonomic to take down One of the easiest tanks I have taken off.
1989 Mazda Rx-7 GXL
kit, reinforcing, tms
Discussing TMS Reinforcing Kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
