Old Fri, Oct-22-2010, 04:40:34 PM   #21
///Motorsport3 kID
yousa nasty bltch, aintcha?
///Motorsport3 kID's Avatar
Reputation: 0 ///Motorsport3 kID has disabled reputation
its normal, you also can hear it when you shut down the engine (the light clanking).
heres a tip, when you shut down the engine keep your foot on the clutch and the noise will stop.
cheers
-r
-Roger
2006 ///M3 Convertible. Imolarot / Black Leather / Cold Weather Package / Nav
Xenon Headlights / H/K Sound System / Painted Corners
12/24/2009 - 16,327mi
1/03/2010 - 19,232mi
3/3/2010 - 23,420mi
4/3/2010 - 25,230mi
10/10/2010 - 36,745mi
3/30/2011 - 45,897mi
10/14/2011 - 54,435mi
Stock
Jump to top ///Motorsport3 kID is offline   Reply With Quote
Old Fri, Oct-22-2010, 07:26:47 PM   #22
E36graduate
Reputation: 0 E36graduate is on a distinguished road
03 - 123,000 miles - original clutch, been doing this since I've owned her.....nothing wrong with my clutch either. My other E46 5MT 328i had very similar clack, clack, clack, just not as loud...probably due to 190 hp versus 350 hp (some mods)?? My 04 S4 6mt did almost the same noises when you pushed in the clutch...clack clack clack.... I've gotten used to these noises my m3 makes. she starts up and drives very dependably everyday....might not sound like a smooth machine....but I kind of like that raw mechanical feeling of the m3.
Jump to top E36graduate is offline   Reply With Quote
Old Fri, Oct-22-2010, 07:33:35 PM   #23
PricklyPete
PricklyPete's Avatar
Reputation: 0 PricklyPete is on a distinguished road
'02 with same issue. It only seems to happen when in stop and go traffic where engine has a load for a very short period of time and then I push the clutch pedal down at the same time I let off of the gas pedal. It seems to happen more on inclines (even slight) more than it does when flat or going down hill.
Almost the exact same thing occured with my '05 Toyota Tacoma V6 that I recently sold...EXACTLY the same sound and scenario where it would occur.
Jump to top PricklyPete is offline   Reply With Quote
Old Sun, Oct-24-2010, 07:24:17 AM   #24
PennStateM3
PennStateM3's Avatar
Reputation: 0 PennStateM3 is on a distinguished road
yep ... only happens for me under load when go very slow on an incline as well (rpms <1K) .. just part of the M experience .... try pushing in the clutch pedal before rpm <1K ... if you push it in at the right moment, you won't hear that rattling sound
KWv2's, Rogue RSM, Rogue RTAB (street version), K&N FIPK intake, Angel eyes, Supersprint Race Exhaust, VMR CSL Reps - hyperblack, Windscreen, JB racing lightweight flywheel + clutchmasters stage II, CDV removal
To come ... hardtop
Jump to top PennStateM3 is offline   Reply With Quote
Old Tue, Oct-26-2010, 04:17:03 PM   #25
///TOMMY S54
///M NUT
///TOMMY S54's Avatar
Reputation: 0 ///TOMMY S54 is on a distinguished road
This happens to me too, I get a rattle 90% of the time when I disengage (push on clutch) in 1st to go into neutral. It never really happens when I'm going into 2nd.
///M3 IR/IR - 6MT
Depo Smoked Corners - Black Front and Side Grills - CF CSL diffuser
1 Piece CF front lip - GruppeM rep exhaust
Jump to top ///TOMMY S54 is offline   Reply With Quote
Old Tue, Oct-26-2010, 10:31:25 PM   #26
16v100bhp
Reputation: 0 16v100bhp is on a distinguished road
From bimerfest - Link
"I’m with BMW of North America, LLC. The M3 is a refined version BMW’s race cars. It is designed to provide optimum power and performance in a street legal package.
In order to transmit engine torque to the rear wheels instantaneously, without any time lag, the whole M3 power train was designed with maximum torsional rigidity. To achieve this maximum torsional rigidity, the flywheel mass and its damping capability has been reduced to a minimum.
As a result, during an abrupt torque transfer (e.g. 1st to 2nd gearshift at low engine speeds) the driver can receive an acoustic feedback, which can be interpreted as a “clunking or rattling” noise.
The acoustic feedback characteristic is not a symptom of a failure, and does not compromise long-term reliability of drivetrain components (clutch, transmission, differential), nor does it adversely affect performance of the vehicle.
If you have any questions, you can phone us at 800-831-1117
Jump to top 16v100bhp is offline   Reply With Quote
Old Tue, Oct-26-2010, 10:41:14 PM   #27
Just say "heavy duty driveline" to yourself while driving. I attribute all noises and clunks to the race track orientation of these cars.
2004 SilberGrau M3 Coupe 6MT
Old Tue, Oct-26-2010, 10:46:29 PM   #28
ire
Why so serious?
ire's Avatar
Reputation: 0 ire is on a distinguished road
This is a relief that the sound can be normal. I hear a similar noise on my '04 w/60k miles most prominently during the 1st --> 2nd shift, but also occasionally (and only slightly) during the 2nd --> 3rd shift as well. There never seems to be a problem engaging; no shuddering, vibrating, etc.
Jump to top ire is offline   Reply With Quote
Old Tue, Oct-26-2010, 11:17:51 PM   #29
BrokenM3
BrokenM3's Avatar
Reputation: 0 BrokenM3 has much to be proud ofBrokenM3 has much to be proud of
Croatia
Originally Posted by Mr.Yi View Post
I know that rattling a bit is okay but when i accelerate in first and push the clutch in (sometimes in traffic) i get MASSIVE amounts of rattling. engagement seems fine (i have 38k miles) but the clutch seems reallly loose with all the rattling. Also when i am doing about 30 in 2nd and a feather the throttle the clutch seems to judder quite a bit. My car also is a 2001 model year.
any ideas? anyway to "tighten" the clutch?
Go to a qualified shop to get i checked out. Had similar simptoms,(@34000 miles)was able to reproduce the rattling under hard braking also. Turned out to be a fallen out flywheel pin, as it slid forward it got into the flywheel, the flywheel tried to kick it out, and as a result, i had a busted bellhousing too.
Hope this is not the case with your car, just sayin' it might be worth to take a look at it. Either way, GL.
Jump to top BrokenM3 is online now   Reply With Quote
clutch, engagement, feels, fine, helpp, looooose, loose, rattles, rattlessss
Discussing Clutch Engagement seems fine but feels LOOSE and rattles! help! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
