Yesterday I made an appointment with a local tire shop (www.telletire.com) to get my rear tires replaced before I head out on a roadtrip this friday(I have the tires, just needed them mounted and swapped out with the old ones). I've been to this shop before with my Cobra, but just to be sure when I called I said "Will your tire machine scratch my wheels? If it will, I certainly don't mind going elsewhere." The guy from the shop on the phone quickly said "no, we do 19 in rims all the time," he even mention he has mounted 24 in rims/tires
. Anyways I go to the shop and the salesman even mentions that his notes attached to my appointment mentions to be careful of scratching the wheels. At this point I felt confident about their service.... let's fast forward 15 minutes when the manager enters the waiting room and says "well we did it." Sure enough they scratched the lip of my oem csl wheel about 70% of the circumference of the rim. I told them don't even touch the other rim. This was around 5pm and their wheel refinishing "go to" shop was close. At this point, I am waiting to hear back from them this morning, but in the mean time, what would you guys do? He asked if we could put the spare tire on for a couple days while it gets fixed.... 1. NO SPARE in the M3 2. I'm getting my tires changed in order to go on a roadtrip 3. He said they can't get me a rental car while they try to fix this before Friday at 4pm (when I'm leaving on said roadtrip)
2005 AW/Cinn 6sp, Vert, oem ZCPs 2001 Mustang Cobra (sold) Last edited by christopherp; Thu, May-20-2010 at 01:41:39 PM. |
You can't give them an impossible quandary - in other words, it sounds like they will fix your rim, but you have to let them have it to fix it.
Make an appointment with them to have the rim fixed next week or whenever you return from the road-trip. See if they can provide you a loaner if you have no other transportation while it's being fixed. Shift happens - the shop is owning up to it. If you work with them you'll have a satisfactory solution.. if you make it hard for them - it's gonna be less satisfactory for sure.
#3 | |
2005 AW/Cinn 6sp, Vert, oem ZCPs 2001 Mustang Cobra (sold) |
#4 |
![]() Location: Indianapolis/Cincinnati
I agree with the response you got.. but that is frustrating had the same thing happen to me except it was all 4! Fortunately for me they did pay to have them fixed.
#5 | |
Are these rims/tires that hard to mount? Seeing that I'm not the only one...
#6 |
![]() Location: NY
If 35 or less profile yes
2002 Steel Gray coupe Mods: H&R adj springs, AC Schnitzer shocks, slotted and drilled rotors, V1, RPI scoops, BMC filter, HPF muffler, Matte CF CSL splitters, Matte Grilles, 6000k fogs, depos, Gutted trunk, No A/C, Sound insulation removed, TRmotorsport MT1. 1997 Cosmos M3 126k, Stock 1994 Schwarz II 325is -Sold 124k, UUC lightweight flywheel w/M5 clutch combo, Ram Air, B&B muffler, H&R springs/Koni shocks, Dinan tune, Hamann HM2 |
#7 |
Flyguy
![]() Location: O'Fallon,IL
Doesn't help you now but for future reference,Autotire in St Peters,MO is excellent. The manager,Keith Emery is a BMWCCA guy and DE instructor. Lots of satisfied customers in the STL area,including me. Also,as Don says,stuff happens,and is a known risk when mounting very low profile tires on large diameter rims. Good luck and hope it works out to your satisfaction.
Mike K. 2005 M3 |
#8 | |
From now on I'll be going there. Autohaus BMW said they won't mount any tire that wasn't purchased from them. My buddy from school's (he also drives an M6) family owns Dobbs Tire. I phoned him and he called and set me up with an appointment today so I can get on the road tomorrow.
#9 |
Flyguy
Not sure about the refinishing. You might check the BMWCCA St Louis website and see if there are any recommendations there. www.stlbmwcca.org
Mike K. 2005 M3 |
| mounting, tire, woes |
