Hoping that maybe someone ran in to this before and can give me some light..
Car is an '02 with SMG. Ran car for about 15 mins prior to changing oil to get it up to operating temp. jacked car up in the front while it was still running to get it prepared to drain. Turned car off, left in 1st with emergency brake on. Performed oil change, everything back together as it was prior to doing oil change. Lowered car down to original position. Went to start the car up, car will not start, wont click over, or do anything. SMG light is now on, when I put transmission in to 1st, it flashes 0, and 1 will not come up. When I have car in 1st, I can push it around as if it was in neutral. Disconnected battery for 20 mins or so, went back out, and getting the same problems. Lights that are on when ignition are on are: SES Battery Oil SMG I thought the SES, battery and oil light all stay on until the car starts up, but I never do remember the SMG light being on before. Can anyone give me any suggestions??
![]() Chris ///Mac '02 BMW M3 Coupe Alpine White/Cinnamon |
JERSEY STRONG
Hood. Open and close your hood. Lights should go off after 6 start ups.
2013 SWP Subaru WRX Hatch
Hood is open.
#4 |
#5 | |
Certified Naysayer
![]() Location: ☻ £ Town ☻
#7 |
![]() Location: Canada
you shouldn't jack the car up while its still running
#8 |
OEM CSL Whoore
did u put the plug back in all the way near the oil filter?
Click my sig and view my pics! Tischer aka GetBmwParts VCSL - Bumper DIY VCSL - Bootlid DIY FS: Rear black door panels FS: Oem trunk |
#9 | |
Tried the opening and closing the hood about 6 times this morning, is there a trick to it, does the ignition have to be on, or smg in 1st, or is there any particular order?? still no luck after trying that this morning...
#10 |
Certified Naysayer
Maybe leave the battery unplugged for 30 mins, reattach and see. Other than that, read the SMG troubleshooting thread see if anything matches.
| car, change, light, oil, smg, start |
