Hello
![]() Location: Florida
I think so. lol
Basically I have clunking in front and can hear it and see it when I push down on the front quarter panels. There was a good deal of play in the strut hats after I cleaned out the bearings and applied new grease. Now when I push down on the car I can visually see the strut shaft assembly move up and down while the hat stays stationary (obviously). ![]() Also, I realized that I didn't install this white spacer. Would this cause my problem? Or are my hats just beyond repair? ![]() Here are a few crappy pics of the new stance with the Eibach Pro-Kit and some Bimmerworld camber shims installed. Thanks! ![]() ![]()
yeh that sounds like a strut hat issue to me
95 SC M3
![]() Location: Eldersburg, MD
The white space has nothing to do with it. Did you get the metal washers installed in the correct order? How did you tighten the top nut?
No matter where you go, there you are! |
#4 |
Hello
I didn't think that spacer was the culprit. I do believe I got all of the washers installed in the correct orientation--I was careful with the disassembly for this very reason.
As for tightening the nut, rubber hose on a clamp to not scar the shaft and a 22mm socket. I've been doing some research and the symptoms sound more and more like shot strut hats. The struts were beyond blown so it wouldn't be a great surprise.
#5 |
Hello
I was thinking, did I not torque down the top nut enough? There was no specific instruction, so I just kind of eyeballed it.
#6 |
![]() Location: DC
There shouldn't be any play in the strut hat bearings. I'd start by replacing them.
There are OEM versions available from RMeuropean and Pelican for around $60. When you reinstall them make sure the top nut is tightened down enough. I'm not sure how you would do this easily with hand tools, but I used an electric impact. |
#7 |
![]() Location: Los Angeles
It is my opinion you didn't torque down the top nut enough. This EXACT same thing happened when I installed Konis on my 2005 Accord. There was visible movement of the shaft when bouncing the car up and down. I tightened the nut further and the strut was then rock solid. Try it out
#8 | |
Hello
#9 |
OEM Lemforders? I ordered new hats when I did my stuff too... everyone said it was unnecessary, then I felt bad.
#10 |
Hello
Yeah, went with the OEM Lemforders. I should have just ordered them from the get-go but when you've done a clutch, cooling, and suspension job in a span of 5 months, you begin to be a bit more cautious with the $$$. lol
| installation, koni, screw |
