| Off Topic Place to discuss this and that. Note: We also have "request to join" forums: Guns and Fitness. (Threads/posts inside may contain material that is NSFW / offensive) |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: PA & MD
I've been there several times.. They have an SR-71, which I've seen before on the Intrepid in NYC but I can't get enough of that plane. The space shuttle they have on exhibit was used for training and never actually went into space.. I like the fact that museum is in set in a hangar, but they need to expand it as there's not enough there imho...
#13 |
![]() Location: Los Angeles
The closest star next to our star (sun):
Proxima Centauri (Latin proxima: meaning 'next to' or 'nearest to')[9] is a red dwarf star approximately 4.2 light-years (3.97 × 1013 km) distant in the constellation of Centaurus. It was discovered in 1915 by Robert Innes, the Director of the Union Observatory in South Africa. The star is the nearest star to the Sun.[8] Its distance to the second and third nearest star, which form the binary star Alpha Centauri, is only 0.21 ly (15,000 ± 700 astronomical units [AU]).[10] Because of the proximity of this star, its angular diameter can be measured directly, yielding a diameter one-seventh that of the Sun.[8] Proxima Centauri's mass is about an eighth of the Sun's, and its average density is about 40 times that of the Sun.[nb 2] Although it has a very low average luminosity, Proxima Centauri is a flare star that undergoes random increases in brightness because of magnetic activity.[11] The star's magnetic field is created by convection throughout the stellar body, and the resulting flare activity generates a total X-ray emission similar to that produced by the Sun.[12] The mixing of the fuel at Proxima Centauri's core through convection and the star's relatively low energy production rate means that it will be a main-sequence star for another four trillion years,[13] or nearly 300 times the current age of the universe.[14] Searches for companions orbiting Proxima Centauri have been unsuccessful, ruling out the presence of brown dwarfs and supermassive planets.[15][16] Precision radial velocity surveys have also ruled out the presence of super-Earths within the star's habitable zone.[17][nb 3] The detection of smaller objects will require the use of new instruments, such as the proposed Space Interferometry Mission.[18] Since Proxima Centauri is a red dwarf and a flare star, whether a planet orbiting this star could support life is disputed.[19][20] Because of the star's proximity, it has been proposed as a destination for interstellar travel.[21] |
#14 |
![]() Location: In my mind
We're going to need some plastic sheets in here to keep people dry from the spray of heads exploding
I'll be sure to keep the latest geekery flowing, here's just a few off the top of my head that always blow my mind:-If the GPS satellites did not account for the fact that time is relative and 'ticks' at a different rate for the satellites than us (because of how fast they are moving, and because of 'Frame Dragging' caused by the earth), the one-third of one-billionth of a second that they 'lose' each day would throw GPS systems out of whack by six miles every day. -Most next-gen 'theories of everything' hold that there are a HUGE number of other universes besides our own, something like 10^500th power. To put that in perspective, the scale of difference between the size of a single atom and the size of the entire universe is 'only' about 10^39. The sheer number of other universes means that any possible arrangement of atoms that could happen, has already and will continue to happen an infinite number of times. In other words, any possible past, present, or future alternate version of reality has already happened an infinite number of times somewhere else. Yes, there is another universe where you are Meghan Fox's panties , and another where you are Meghan Fox :mega ****ing shifty:. The distance to the closest universe hosting a parallel version of our own reality has been approximated, but it's so far away that if you were to have a 1 followed by zeros where each zero was represented by a single atom, there are not enough atoms in the entire universe to even come close to expressing the number.-Time travel into the past is impossible. However, time travel into the future is already proven to be possible, albeit infeasible with current technology. -Every single atom and element in the entire universe, EVERY single one, was created inside a star during its life or death (except for hydrogen, which was a product of the Big Bang itself). We are literally stardust. ![]() |
#15 |
#16 | |
Admiral Douchington
- Chris 2004 Mystic Blue Metallic Convertible
#17 | |
How many licks..
![]() Quote:
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪ ![]() 97' M3. '10 R6. |
#18 | |
How many licks..
http://online.wsj.com/article/SB1000...atestheadlines
#19 | |||||
How many licks..
Plasma rocket could revolutionize space travel
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
#20 | |
Atoms are 99.99999999999% empty space. If you removed all the space between the atoms of the earth, it would shrink down to the size of a grapefruit, and you'd be left with a black hole.
Japan to build orbiting solar station to beam energy back to earth (semi-old but don't think it was posted): http://www.physorg.com/news172224356.html Quote:
| announcement, buzz, creates, nasa, space, things |
