#11 | |
Panther fans get on your feet
![]() Location: Philly
OP, the best thing I think you could do is measure the resistance of the bulb using an ohmeter and then work backwards. Wire a resistor in series with the bulb (as previously suggested) that will give you a current reading similar to what you would get with a normal bulb. One thing I did for my ZKWs (because I use a PnP switch with a relay to activate the lights) was wire a resistor between both + and - wires to resemble the draw on a regular headlight. A relay will draw on the order of milliamps and you need something on the amps to stop the OBC from tripping. Obviously your taillights might draw a different resistance than headlights, so I can't say for sure what resistance you should use, but probably no bigger than 12 ohms.
-Sam ![]() Mods: RMS Vortech V1 Supercharger, M50 manifold swap, B&B tri-flo DTM exhaust, Ron Stygar Custom SS kit, autometer oil temp. and boost gauges, ASC throttle body delete, H&R Springs, Bilstein shocks, Dinan rear strut tower brace, Mason front strut tower brace, UUC Barbarian front/rear sway bars, X-brace front subframe connector, JTD rear shock mounts, Steel braided brake lines, yellow tinted fogs, genuine euro plate, ZKW headlights with 8000k LED angel eyes, racing decal, and other stuff |
#12 | |
![]() Location: Pittsburgh
| bulbs, code, led, light, trip |
