Old Wed, Jun-09-2010, 02:38:22 AM   #101
Mr. Shadow
Mr. Shadow's Avatar
Reputation: 0 Mr. Shadow is on a distinguished road
Originally Posted by excessive View Post
That is correct, the exhaust bolts had no wear on them, only the intake ones were loose. As for the intake cam bolts, they were all loose, some of them had worse wear than others, but all had wear marks. One was almost 50% worn through.
That's really scary
Jump to top Mr. Shadow is offline   Reply With Quote
Old Wed, Jun-09-2010, 02:42:13 AM   #102
Krehtan
Krehtan's Avatar
Reputation: 0 Krehtan is on a distinguished road
Is there any chance you could post a sound clip of your engine now that you've done the repair work?
03 CB/Cin
Jump to top Krehtan is offline   Reply With Quote
Old Wed, Jun-09-2010, 11:47:55 PM   #103
excessive
Reputation: 0 excessive has disabled reputation
any particular reason why? it sounds like a smooth running S54.
I dont' have any sound clips before I did the repair, I guess i should have gotten one.
Jump to top excessive is offline   Reply With Quote
Old Fri, Jun-11-2010, 04:04:02 AM   #104
kaiv
SoCal vanos/valve specialist :D
France
Excessive, thanks again for all the research you have done and for posting the findings in such a detailed manner
I have seen pictures on this very forum of vanos/cam gears/sprockets and what not shooting through the valve cover and have been wondering how and why such failure can occur. As far as I'm concerned this issue has sort of been a mistery until now. So thank you for sharing all this precious information with the community!
My 02/01 M3 has 127k miles and although it doesn't make any unusual noises it sees a lot of track time and I've been worried about this too.
Luckily I checked everything today and everything is 100% tight.
If anyone is interested I have a set of 12 new OEM bolts and 1 new OEM vanos gasket available FS.
AW S65 E92 6MT
past: AW S65 E90 6MT- LSB S54 E46 6MT- JB S52 E36 5MT
Kaiv's SoCal Feedback! [M3Forum] [iTrader] [Bimmerforum]
Old Fri, Jun-11-2010, 11:26:31 AM   #105
excessive
You're welcome. And as I've stated several times, 2001-2002 M3's don't seem to suffer from this problem!!!!
Old Fri, Jun-11-2010, 04:44:26 PM   #106
F85W31
...souped? That's the driver, not the car, now let's go...
F85W31's Avatar
Reputation: 0 F85W31 is on a distinguished road
Default Collateral Damage?
Excessive, thank you for the sharing of information through your great writeup. Has the potential for bottom end problems been mentioned by the master tech? All those metal shards represent contamination well beyond normal wear and will be distributed though the lubrication system despite the oil filter. Based on your photos, the fasteners are literally ground down to fine particles. Main bearings and possibly cam bearings come to mind...
2006 Individual Collection Chiaretto Red and Arizona Sun Full Leather
275/30/19 and 295/30/19 on CCWheel 9.5"x19" and 10.5"x19" 505As
Jump to top F85W31 is offline   Reply With Quote
Old Fri, Jun-11-2010, 04:59:42 PM   #107
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Question
OP, how did you ensure that there was no amount of oil in the cam gear bolt holes when you installed the new bolts?
I assume that any oil in these holes could be a big problem...
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Fri, Jun-11-2010, 07:01:38 PM   #108
kuksul08
Excellent DIY. I will surely wiggle my cam gear next time I do the valve adjustment.
I would probably spray some brake/contact cleaner in those threads and use a bunch of red loctite to ensure they never come out!
S54 Valve Adjustment DIY, Excel, Print out:
http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
Old Sat, Jun-12-2010, 02:29:06 PM   #109
excessive
You have a good point, that metal had to go somewhere - but there's really nothing I can do about that now. The engine runs great, so I guess I will just keep hoping that it stays that way for a while longer! THANKS AGAIN BMW!!!
I did try to sort of wipe out the bolt holes with a Qtip, but there really wasn't much oil in the holes. I guess I probably should have mentioned that in the DIY, but I really believe that the real reason they come loose is that they are not the right hardness. I don't think it has much to do with the loc-tite at all, but it surely can't hurt.
Old Sat, Jun-12-2010, 04:42:53 PM   #110
jones
jones's Avatar
Reputation: 0 jones is on a distinguished road
In my experience (limited though it is) oil between the bolt and the hole doesn't matter if you're using loc-tite. In fact, it's usually good to have some in there.
Granted, I've never replaced the VANOS bolts. I'm talking mostly about main bearing bolts and such on other engines.
2002 Steel Gray Metallic
6MT
Jump to top jones is offline   Reply With Quote
bolts, diy, fix, lose, lots, pics, vanos
Discussing DIY: Fix your lose VANOS bolts! LOTS O' PICS! in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
