Old Wed, Jun-09-2010, 04:02:33 PM   #1
cbformula
Reputation: 0 cbformula is on a distinguished road
Default What does this indicator mean? (photo inside)
So Ive been getting this little yellow icon more and more lately. Can anyone tell me what it means (dont have my manual anymore).
It lights up after my car has not been started for awhile (eg over night). It also lights up when Im on a steep hill or when I make long semi hard turns (like going on an on ramp toward a highway). But after I drive the car a bit, or am back on a flatter surface, it goes away.
Can anyone tell me what might be wrong?
Thanks in advance!
2004 Estoril Blue M3
Delivery--9/25/04
Jump to top cbformula is offline   Reply With Quote
Old Wed, Jun-09-2010, 04:05:36 PM   #2
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Looks like low coolant light. Have you checked your coolant?
Mr. Wolfe
2003 Alpine/Cinnamon ///M3 Coupe 6MT
ZCP Wheels l 4.10 Diff. l KWv2 l JVT l ESS l H&R Sway l AR-20's l 10mm/15mm Spacers l ZHP Shift Knob l FK 452's l RE l PF
Old Wed, Jun-09-2010, 04:07:03 PM   #3
rh_wa
Objects in mirror are slow...
rh_wa's Avatar
Reputation: 0 rh_wa is on a distinguished road
^ yup...add coolant.
2003 vert | steel gray metallic
Jump to top rh_wa is offline   Reply With Quote
Old Wed, Jun-09-2010, 04:09:10 PM   #4
cbformula
Oh ok, thats the coolant - haha thanks! Do I need special BMW coolant like they have their unique sythetic oil or can I use a coolant from my local auto shop?
Delivery--9/25/04
Old Wed, Jun-09-2010, 04:13:10 PM   #5
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Order or buy some BMW Coolant and in the meantime, top it off with some distilled water.
Mr. Wolfe
Old Wed, Jun-09-2010, 04:15:43 PM   #6
Michalek0915
04 M3 SMGII
Michalek0915's Avatar
Reputation: 0 Michalek0915 is on a distinguished road
Definitey Coolant Light. I'd check your fluid and for precautions go to BMW dealer and pickup a bottle of coolant.
Mods - Highline Intake System, VMR V715 19" Wheels, Agency Power Exhaust V2 W/Titanium Tips, Powerflex RTAB's & FCAB's, StopTech Stage 2 Brake Upgrade Kit W/Axxis Ultimate Pads & Slotted Rotors, CSL Half-CF Rear Diffuser, Front CF Lip, Koni Yellow Adjustable Shocks W/ Eibach Pro Springs, Depo Smoked Corners, Blackout Grille & Kidney Set, Umnitza Orion II Angel Eyes, Stealth Bulbs, Painted Reflectors, 30% Tint All Around, Blue LED Interior, Tennis Balls, JL Audio 500/1v2 Slash & Wicked C.A.S Enclosure W/ 12" W3v3.
Jump to top Michalek0915 is offline   Reply With Quote
Old Wed, Jun-09-2010, 04:49:52 PM   #7
JEROM3
my silver bullit
JEROM3's Avatar
Reputation: 0 JEROM3 is on a distinguished road
you might as well check your oil level too.
Jump to top JEROM3 is offline   Reply With Quote
Old Wed, Jun-09-2010, 05:06:55 PM   #8
blue dragon
Proudly Canadian
Reputation: 0 blue dragon will become famous soon enough
It means you should read the manual that came with your car...........
Happiness is not just around the corner, it is the corner!
Jump to top blue dragon is offline   Reply With Quote
Old Wed, Jun-09-2010, 05:20:44 PM   #9
PeteyyPab
So long M3, its been a trip!
Reputation: 0 PeteyyPab has disabled reputation
Italy
Save this for a rainy day...
http://www.bmwusa.com/PDF_4b414f52-a...f8111e8ec.arox
TOTALED: 3/20/2011 - ill miss u, HELLO: M5, Looking forward to the journey
In the cool still hours of night, you can still hear my subframe pulling away and my VANOS bolts backing out.
VERT Subframe mount failure confirmed 5/4/2010
Jump to top PeteyyPab is offline   Reply With Quote
Old Wed, Jun-09-2010, 05:33:07 PM   #10
E36graduate
Reputation: 0 E36graduate is on a distinguished road
You most likely have a small leak somewhere.....get under there and check it out before you get stranded. I had to overhaul my cooling system on my old E46 328i a few times in 200,000 miles, however the water pump was like $70.
Jump to top E36graduate is offline   Reply With Quote
indicator, inside, photo
Discussing What does this indicator mean? (photo inside) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
